apparently i need to read the other posts my Strada is overfilled with oil and i just didnt take time to check that till i read another post its full to the top and thats after leaking!
I had something that at first looked like a radiator leak, but upon further inspection it appeared to be oil of some type. I carefully washed the radiator with soapy water. So far all seems good after many miles of off road/dirt roads.
I would check the oil line coming out of the upper frame on the left hand side as your looking forward. Its just a rubber line with a band clamp and mine was leaking there slightly
Did you do an oil change or check the oil lately? Is your oil cap real tight? Or maybe too much oil? Have you read this thread? Post #22 http://www.cafehusky.com/threads/oil-leaking-at-the-near-the-telltail.34201/page-2#post-326952
I had this happen too right after buying the bike in December. I thought I punctured my radiator - but I washed it off and it went away.
