125-200cc Front suspension ( fork ) setup
Discussion in '2 Stroke' started by david.bergen, Jun 23, 2014.
  1. david.bergen Husqvarna
    Belgium
    wr 125
    Ajp pr4 240,beta xtrainer,beta rr250
    I tried to dial my bike in this week.
    New 2013 wr 125
    I got the rear set as the specs in the suspension thread. (Little less preload and bingo correct specs)
    Now the front is a different animal.
    Bike sag is 30 mm and rider sag is 40 mm. Me on or off the bike just makes a difference off 10 mm.
    My weight varies between 155 and 158 pounds (70-72 kg).
    Following the specs I need 75 mm rider sag at the front
    The extra sag at the front is really welcome as I am a short guy and can't get my feet on the ground.
    Maybe if I have to do the costs, it is better to have the bike completely lowered with the correct springs in the fork. At the moment I run the bike with the fork +1cm in the triple clamps but have still loose front wheel traction in tight slow twists.
    What do you think changing the front springs (which ones) or a complete suspension modification?
    Money is a little tight at the moment, but good suspension setup is important for me.
    Al suggestions welcome.
    Best David
