TE/TC Front tire ideas
Discussion in '2st' started by HS507, May 6, 2017.
  1. HS507 Husqvarna
    NE Ohio
    Te 300
    Yz450,crf150r,crf100f,crf50f
    I race harescramble and needing a new brand and make of front tire because i enjoy trying something different. What are you all running?? Im on every type terrain racing. Thanks
  2. ptkatoomer Husqvarna
    San Diego area
    None
    2020 ktm 300 xc-w, 2020 ktm 500exc
    Hard to go wrong with the goldentyre fatty 216.
    hakkalugi and HS507 like this.
  3. Big Timmy Husqvarna
    (South Eastern) AZ.
    I agree with the above. The 216 is a great tire. I have ran the Fatty for a few years now.
    However I am currently running the "Golden Tyre" Desert one 216 DST 90/100/21". Its the same pattern but has a bit taller knobs (15%) when new and it has a 4-ply carcass rather than the 2 ply of the 216AA "Fatty".
    It probably suits my conditions here in the AZ desert a little better than the Fatty.
    You can't beat either one IMHO.
    HS507 likes this.
  4. HS507 Husqvarna
    NE Ohio
    Te 300
    I just gave my used 216 fatty to my brother cause he runs front tubliss, might be better at 6-8psi.
    Thinking of the metzler 6days or the pirelli mt16 front. I slso hear the bridgestone m59 is good
  5. NH-JP 2nd Fastest Old, Slow Guy!
    New Hampshire
    2017 TE300
    1988 Honda Hurricane,
    For New England woods, the m59 is hard to beat.
    Mt16 rear.
  6. racemx904 Husqvarna
    owenton, ky
    2014 Beta 350RR & 1986 430XC
    I might try that m59 next....
  7. Boogie Husqvarna
    Australia
    Red head
    Michelin comp 6
    90/100-21
    Try one of them
  8. hakkalugi Husqvarna
    North East PA
    17' TE150
    Im running this paired with the tubliss system, im extremely happy with it.
  9. Stiggy Pop Husqvarna
    '17 TE150
    KTM 200exc
    Yup this combo just flat out works in the woods
  10. NH-JP 2nd Fastest Old, Slow Guy!
    New Hampshire
    2017 TE300
    2nd that on the Tubliss!
  11. gots_a_sol Husqvarna
    Charles Town, WV
    WR177
    17 250RR
    I've been running the Shinko 546 fatty. Extremely pleased with it. Being cheap is a nice bonus.
  12. ptkatoomer Husqvarna
    San Diego area
    None
    What's the lowest pressure you've run? I'm running10psi with a heavy-duty tube. Wondering how low you can go before it starts to roll or feel wobbly......
  13. hammer Husqvarna
    I run a fatty front with Tubliss and find anything under 10psi the tire starts to roll.
  14. Big Timmy Husqvarna
    (South Eastern) AZ.
    I had the same experience as "hammer" with the 216 Fatty as well. I thought maybe it was just me weighing in at 245lbs. Lol.
  15. NH-JP 2nd Fastest Old, Slow Guy!
    New Hampshire
    2017 TE300
    I run the M59 or MT16 between 8 and 12 psi on Tubliss at 185lbs without gear.
    Minimal roll.
    I tend to have the perspective with the Tubliss of this:
    I run my normal tire PSI and the Tubliss prevents me from getting a flat.
    I don't run super low pressure expecting performance enhancements, just hate changing flats in the field, and carrying irons.
  16. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
    2011 TE449 2006 WR250
    I've got the DST on the 449 and AA type on the 250. The DST has well over 1500 miles on it. It's finally starting to chunk off some side knobs from the rock gardens but still carves and tracks very well. I think I have one more in my stash. I did find out that Golden has discontinued the DST so if you want one and see it available, I suggest you grab one. The only thing I've found that the fatty doesn't like is slick moto track. It tends to push and hunt in the wet stuff.
  17. lankydoug Husqvarna
    MO
    WR
    TM 300en
    I run Tubliss and from my experience a lot of tires that do not perform well with tubes do great with Tubliss. I choose an intermediate desert tire with a stiff sidewall and run 7-8 psi in the front and 4-6 psi in the rear. I have run a MT43 at 80 miles per hour with 5 psi and no stability problems at all. I've tried several motocross tires and if I don't run more psi they will rip side knobs and start weeping slime from the rips. I have got staub punctures on the rear tire several time and with stiff sidewall tire I've gone many miles with zero psi and no loss in performance. I went 9 miles on an flat Dunlop mx tire and the Tubliss kept it on the rim so I could finish the hare scramble but the inside of the sidewall was shredded from heat and overworking it. If you recognize that you have a flat you can stop and worm patch it and if you have a compact bicycle pump you are good as new. The last Sedona tire I used had 3 staub flats before I went with a new tire one of which was so bad I had to double up the worm patch. To me the upside of Tubliss is you can get trials tire grip and mx tire performance out of a long lasting desert tire and fix flats without breaking down the wheel and tire. (a pump and worm patch weighs less that one tube and can fix both front and back.)
    ptkatoomer likes this.
  18. NH-JP 2nd Fastest Old, Slow Guy!
    New Hampshire
    2017 TE300
    I agree with lankydoug. I just carry 2 co2 cartridges instead of the pump!
  19. robertaccio Husqvarna
    San Diego, Ca
    2021 Husqvarna TE300i
    GT216AA 2PLY IS THE LATEST GO TO RUBBER FOR A WIDE RANGE OF TERRAIN. WIDE KEEPS YOU ON TOP, LARGE CARCASS HAS ALOT OF GIVE FOR ROCKS. fitted with an M16 Michelin Bib Mousse and stuffed after some ride time.
    And no Im not yelling...just left on the caps lock.
    hakkalugi and Big Timmy like this.
  20. reveille Husqvarna
    Northern Illinois
    2014 FE501
    2015 300 XC W
    WHAT HE SAID! ^^^ LOL
