Front Turn Signals/Blinkers not working--Goofy
ktmhusky
Goofy problem. Front turn signals are not working. I have used a test light to check the wires and the test light blinks when test light is attached to negative battery terminal and the signal wire. Then when I put a bulb in (and yes I have tried numerous bulbs), they don't blink. This makes no sense to me. I have also checked the ground with the test light lead on the positive terminal of the battery and the ground wire and it lights up.
Any other ideas. Help is greatly appreciated.
