250-500cc Front wheel spacer size.
Discussion in '2 Stroke' started by Makntracks, Oct 14, 2016.
  1. Makntracks Husqvarna
    darwin, NT
    Wr300
    Rocker c
    Hi All,
    Just picked up a second hand 2013 wr300.
    And after the first ride realised the previous owner forgot to put the front wheel spacer back in last time the wheel was off and its no where to be seen.
    Just wondering if any one could get me the dimensions off theirs or have one they would like to offload. 5 week wait form husky. :banghead:
    Cheers
    Mick
  2. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    Thinkin got a spare used one that will get ya putaa trouble. Pm me ya address mate n il send it off(if still hav it il Chek tomoro am!)
  3. CCP Husqvarna
    NJ
    04 WR250 11 WR250
  4. Makntracks Husqvarna
    darwin, NT
    Wr300
    Rocker c
    Mate, that would be awesome. I'll PM you.
  5. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    Can sum1 please giv me the dimensions of the rear wheel spacer? Need overall length, ID, both ODs n the flared section depth/height. Cheers
  6. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    Nobody got their rear wheel off n cn measure for me? Don't hav access to bikes ATM as at work
  7. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Sorry dude don't think my huskys the same, doesn't the manual spec the spacer sizes?
  8. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    Dunno bout manual mate it's the rear spacer with the flared end I need. Makin em at work outta Staino for makntracks(OP) bought spare front but didn't hav time to take rear wheel off n bring one.
  9. Hurky Husqvarna
    Spain
    ex: WR300 2010
    Honda CR500AFX + Beta RR300
    I have a drawing of the rear spacer from my WR300 2010, I can sent that later...
  10. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    Cheers
  11. Hurky Husqvarna
    Spain
    ex: WR300 2010
    Hi all,
    It took me some time to find this picture from 2014, bur here it is:
    OD=32mm
    ID=25mm
    L=16,7mm
    The flange is about 3mm thick (not measured)
    I find out that both ID and OD does match the CRF rear spacers, but the CRF ones are much larger, a friend gave me some spacers he made from Stainless on the CNC and I cut them down to 16,7mm and they fit perfect:
    On the front I used the CRF spacer as it + a 2mm thick 25mm ID washer, also in stainless.
    I hope that this info is helpfull...
    Cheers :D
    mr_manny likes this.
  12. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    Cheers hurky, perfect!
    16.7mm height/length seems small? Don't spose u cn tell me wat the OD of the flanged area is? Prob makes bugger all diff really anyway
  13. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    The flange is to distribute pressure on your swing arm, you could do like Yamaha have as big flange with a taper on so the wheel slides in nicer.
    Hurky likes this.
  14. Hurky Husqvarna
    Spain
    ex: WR300 2010
    I have mesured the front spacer and it is 26mm long, ID and OD is same as the rear.
    The flange on the rear has a OD of 42mm and is 4,5mm thick.
    Regards ;D
  15. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    Cheers mate
  16. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    Dun Makntracks!
    Hurky, juicypips and gots_a_sol like this.
  17. gots_a_sol Husqvarna
    Charles Town, WV
    WR177
    17 250RR
    Thanks for the dimensions.
    I just got my new-to-me lathe running today so this seems like excellent project to start wasting metal on :D
    shawbagga likes this.
  18. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    Dunno wat grade stainless it was but it was fricken hard!!! Old pump shaft. Mate that did it was really crackin the shits(old lathe n tips, 45 degrees, flies, hangover). Was quite funny :)
    johnnyboy and juicypips like this.
  19. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    If anyone else in Oz wants sum let me know boys always kn for free beers after work
  20. Hurky Husqvarna
    Spain
    ex: WR300 2010
    These look gr8 ! Good work
