Frozen/broken rebound adjuster!
Discussion in 'General (Main)' started by letitsnow, Feb 19, 2010.
  1. letitsnow Husqvarna
    mn
    FC250
    CBR600F4
    One of my rebound adjusters was froze up and I have broken the top (where to stick a screwdriver in to adjust) off.
    What should I do now???
  2. letitsnow Husqvarna
    mn
    FC250
    CBR600F4
    The adjuster screw only pushes the rod up and down correct? Would it work if I drill and tap the hole for a regular bolt, then use a locknut on top to lock the bolt at the height that works best??
  3. letitsnow Husqvarna
    mn
    FC250
    CBR600F4
    This doesn't look very good, but it is functional. :thumbsup:
  4. AndrewS Husqvarna
    Niagara Region, Ontario, Canada
    2015 FE350s 2013 TE310R
    2009 TE250 (sold)
    Sounds like you got the important part covered! :)
  5. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Go to Marzocchi, Usa.
    Mine did the same thing and the parts were cheap and they just regular mailed them since they are light. Hope you didn't really drill it out and use a bolt because a $10 fix is now about $75 for the spring cap. Hall's (Springfield, IL) might have a used one?
    Real easy to replace and use antiseize on them and adjust the ball bearing and spring just till you feel the click when turning them. Alway shoot wd 40 or something in them before you turn them. They corrode and break.
    Go back and look cause I had a thread on this.
    Thanx!
  6. letitsnow Husqvarna
    mn
    FC250
    CBR600F4
    ^^ Too late, but thanks for the info - I will keep that in mind for my good bike.
