I don't have access to my bike to measure, and need to order some additional fuel line for it. Does anyone know the correct stock ID size for the fuel hoses? Thanks.
6mm ID. 6mmID x 10mmOD or 6x11 is common. I also selected a heat resistant version since I have an IMS tank and the front left hose passes less than an inch from the exhaust header. The stuff I found is black and you can put a soldering iron against it and nary a mark is left. 3/16" streched a bit works. 1/4" is a bit on the loose side for some type of hose but may also work with clamps.
