Fuel Pump Connector
Discussion in '610/630' started by Nick Taylor, Oct 29, 2013.
  1. Nick Taylor Husqvarna
    Banchory, Scotland
    TE 630
    Anyone know where I can get a replacement connector for attaching the pipe that goes from the fuel pump to the tank. I had the tank unscrewed and accidentally knocked it off the bike. It snapped off the pump power connector and the connector at the engine end. I'll bodge the fuel pump end and I guess could use a jubilee clip at the tank end but it would be nice to find the proper connector. Does anyone know what it's called?
  2. Circus Husqvarna
    San Diego
    Shawbridgehusky and Nick Taylor like this.
  3. DYNOBOB Husqvarna
    The pump in inside the tank. Sounds like your asking for the fuel line that runs from the tank/pump to the fuel rail. I'd just order a new one at the dealer or find someone with a Safari tank that isn't using their stock line. Fuel in that line is already pressurized to 45psi. It may be tough to get the broken end out of the tank/pump. The electrical connector may be tougher to fix, a pic would help.
  4. Nick Taylor Husqvarna
    Banchory, Scotland
    TE 630
  5. Nick Taylor Husqvarna
    Banchory, Scotland
    TE 630
    It usually takes around 2 months to get any parts from Husqvarna. I'm in the UK.
  6. Nick Taylor Husqvarna
    Banchory, Scotland
    TE 630
    Oh and every pump in the factory is faulty so I won't be buying a new one. We've had one bike that has been with the dealer for 16 months and has gone through every pump Husqvarna had on the shelf and they were all dodgy.
  7. Nick Taylor Husqvarna
    Banchory, Scotland
    TE 630
  8. DYNOBOB Husqvarna
    Is that a crack in the tank?
  9. Nick Taylor Husqvarna
    Banchory, Scotland
    TE 630
    You just made me run out and check. No thank goodness. It's just a shadow. Fuel is leaking out from the bottom half of the pump though. It must have gotten pulled out a bit. you can see it in the photo.
  10. DYNOBOB Husqvarna
    I don't think there's really an option but to get a new fuel line. The inside of the stock line has a hard teflon liner that is hard to seal up to with a new connector and would probably be too short once you cut the old plug off. I found this out when I installed a "T" for a fuel pressure gauge. You're lucky it didn't snap off at the tank side. It's a little tough to get the connector out of the pump even when it's not broken. I used several jewelers screwdrivers pushed in to get it to release.
  11. Nick Taylor Husqvarna
    Banchory, Scotland
    TE 630
    Finally got a new fuel line. Bike started first time and ran for a while. I switched off and when I went to start it again I couldn't get it to start. It turns over fine and sort of catches but just doesn't fire fully. Any ideas?
  12. DYNOBOB Husqvarna
    Air need bled from the line? Maybe try starting and keep running on starter fluid for a minute?
    Make sure your battery is fully charged.
  13. Nick Taylor Husqvarna
    Banchory, Scotland
    TE 630
    Finally got it going again. Good call with the battery. It sounded like it was turning over fine but it obviously needed a good topping up. Does have a slow drip of fuel coming from the fuel line at the pump end. When I turn the throttle it now cuts the engine. It used to do that just before I did the power-up and I'm hoping it's something to do with that.
  14. EricV Husqvarna
    I don't know how you guys even get that fuel hose attachment off from where it meets the pump...I can never seem to do it and, granted, give up quickly for fear of breaking it (so instead I disconnect the fuel line where it clips to the throttle body- that clip is easy to squeeze/manipulate- you can tell by looking at it how it works.)
  15. Nick Taylor Husqvarna
    Banchory, Scotland
    TE 630
    You just push the ring towards the pump. You have to push quite hard until it clicks.
  16. EricV Husqvarna
    Appreciate the tip. I'll probably continue to disconnect at the other end, seeing as this area of this bike (what with broken connectors, fuel lines, leaking/failing pumps) seems to be more like a porcelain doll than a dirt bike. :)
