Fuel Pump Issue
Discussion in '610/630' started by asi00007, Apr 20, 2013.
  1. asi00007 Husqvarna
    TE 630
    Suzuki V-strom 1000
    Hi Guys
    I got my 630 two month ago and I did 800 KM on it.. I just love that bike.. amazing what I can do with it.. well.. its me how try to keep up with the bike
    But I have a problem .. Yesterday i took a ride to the bush and everything go well until we decided to head home , so I'm trying to start up the bike and nothing happend .. the fuel pump doesn't make any noise .. everything else is working fine .. after a few phone calls I tried again and suddenly it making the regular BZZZ and she fire up in a second and the N flash once , I'm going tomorrow to the dealer to sort that out but I wonder if anyone else here had the same problem .. I didn't find any information on CH but I'll be happy if someone have information about this issue
    Asi
  2. WickedWill Husqvarna
    QLD,AU
    some little red ones
  3. DYNOBOB Husqvarna
    Sounds like a little different problem than I had. It does point to the usefulness of a led wired into the fuel pump to indicate power. Power but no running pump tells you bad pump. No power to pump= kill switch? ignition switch? pump relay? loose/bad tip bypass plug? ?? Hopefully you threw a code the dealer can see.
  4. asi00007 Husqvarna
    TE 630
    Suzuki V-strom 1000
    Ok..
    I dropped the bike at the dealer and he checked the kill switch , clean it and said he run the bike for 30 minutes and didn't find any problem with it.
    Yesterday I road to the city , it took me 45 minuets to get there , I spent about 10 min in the shop and jump one the bike .. trying to start it and AGAIN... the same symptoms ... no noise from the fuel pump and I couldn't start the bike... so I wait little bit more and then she start without no problem at all..
    Its something related to the temperature , Its not the sensor problem sins the fan doesn't work when I turn the switch on when she cold
    Any ideas ?
    Asi
  5. DYNOBOB Husqvarna
    You've got a problem that's impossible to diagnose without some testing. First, you need to know if the pump is getting power when you hear no pump noise. If it is getting power you've got a bad pump or loose connection in the fuel tank at the pump. If it's not getting power you have to start working your way upstream. Ignition switch, kill switch, fuel pump relay, etc.
    This is the LED I wired into the pump power/ground wires and mounted on top the speedo. Green/red is 12v and the heavy black wire is ground.
    http://www.autozone.com/autozone/accessories/Type-S-Charcoal-gray-micro-dash-lights/_/N-6geb?itemIdentifier=765793_0_0_
  6. asi00007 Husqvarna
    TE 630
    Suzuki V-strom 1000
    Ok ..
    So yesterday on my way home it happened again.. but before the engine cut off I manage to here the pump making bad noises (like water pump you plug one end ) and then it died ... gave her to sit for 15 minutes and she fired up like new...
    so tomorrow I'm at the dealership and he will start to run the warranty claim
    Ill keep you posted
  7. Blazes Husqvarna
    South Africa
    Eddie Seel 634SMR works Replica -
    Aprilla Dosodoro 2X 2009 610
    Had the same symptoms with one of my 610TE's
    Bought a 2 aftermarket pumps from --think it was Cycle works --same as the 690 ktm -- fitted it and that was that -- never gave me a problem again --
    Now that I have one as a spare I doubt I will ever need one again ---:)
  8. asi00007 Husqvarna
    TE 630
    Suzuki V-strom 1000
    I wold do it without a second thought but the bike is under warranty so I'm letting them to deal with it
  9. DYNOBOB Husqvarna
  10. asi00007 Husqvarna
    TE 630
    Suzuki V-strom 1000
    Thanks Mate ! Ill order one just in case
