i solved the engine problem..now my fuel pomp is not working.When i put the ignition on,it dosnet makes that sound. dzzzzzzzzzzz. Any ideas? thanx
When my pump quit it was the fuse. On the 630 the fuses are mismarked (don't know about 610), check all three. edit, just saw your response. Probe the wires at the pump for 12v when you turn on the key. .
No, unplug the fuel pump and make sure it is getting power by checking for 12v at the plug when you cycle the key. It should come on for 2-3 seconds. If you're getting power, you've ruled out the fuse and everything else, so it MUST be the pump or internal wiring.
