Blown fuse 2 again , also plate light , so replaced fuse and bulb . Turned key on , engine check light on and bike won't start. All the fuse 2 parts work , headlight/high beam / low beam , horn , brake light , plate light but bike only turns over . So take fuse 2 out and bike starts and engine check light goes out. I can't remember this happening last time. My auto electrician charged me $700nz and wasn't even sure what he had done to fix problem apart from open loom up rear and middle of bike and move a few wires around Damn frustrating
. Wonder if it could have been a short in the loom someplace and by moving the wires around was lucky enough to relocate any bare wire from contacting other wire/frame.
Found it! Bloody crap engineering / wiring route I'll post pics tommorrow but you were right LED . The loom had rubbed through between subframe and fuel tank Behind red plastic . The wires were of course the number plate bulb. Could only just move loom enough to see rub mark. Weird that bike wouldn't start but lights worked , great safety feature I suppose. Not an easy fix but not impossible. I'm pissed off that my sparky didn't look hard enough 15 months ago. This was the problem all along.
