125-200cc Gah!!! help
Discussion in '2 Stroke' started by jimmyjamez12, Mar 19, 2014.
  1. jimmyjamez12 Husqvarna
    pittsburgh pa
    04 cr125
    03 KX100, 06 KX85, 01 PW80
    So i bought a cr 125 a few weeks back. 2004. It felt like good compression kicking it slowly by hand. fired first kick. throttles up good. i took it for a little spin finally and it boggs horribly up any kind of small hill or under load. Im hoping it just needs a carb clean from sitting. maybe sticking reeds? Any easy ideas to keep it simple before tearing the top end fully apart?
  2. jimmyjamez12 Husqvarna
    pittsburgh pa
    04 cr125
    Oh but if i feather the clutch and throttle it Will all a sudden lift the front end and rip up the hill
  3. PowerKord Husqvarna
    Notheast Ohio
    2008 WR 250 Sold
    2014 Sherco SE-R 250
    Sounds like the problem may very well be somewhere in the intake. Take the carb off and clean it and make sure the floats are working correctly. Also check te shape of the reed valves. Then fire it up and see if it's any better. If you don't know the history of the bike, you'd be well advised to do a top end job before the top end grenades.
  4. rockdancer Husqvarna
    Sunshine Coast, Australia
    2013 WR125, 2019 FE350
    its just jetting - check plug
    IM0 it will be rich try adjusting needle to second slot and or leaner pilot
    find out settings
  5. jimmyjamez12 Husqvarna
    pittsburgh pa
    04 cr125
    Ya the guy knew nothing of the history. i was hoping to get a few rides in before tearing it down. so far i pulled mouse nest from air box :-/ pulling carb now. thanks
  6. jimmyjamez12 Husqvarna
    pittsburgh pa
    04 cr125
    AAnd the air filter sticks to the wall if thrown hard enough lol
  7. jimmyjamez12 Husqvarna
    pittsburgh pa
    04 cr125
    Internals of the carb are spotless
  8. PowerKord Husqvarna
    Notheast Ohio
    2008 WR 250 Sold
    Did you look at the plug?
  9. jimmyjamez12 Husqvarna
    pittsburgh pa
    04 cr125
    Jets appear to be 633? With r-5 below that number and 3.8
  10. jimmyjamez12 Husqvarna
    pittsburgh pa
    04 cr125
    Plug is perfectly brown
  11. yzrider Husqvarna
    2004 cr125
    2009 yz250f 197? rickman zunpaap 125
    Its the carb for sure. Spotless inside doesnt mean all the jets are 100% clean inside them,
    Motosportz likes this.
  12. jimmyjamez12 Husqvarna
    pittsburgh pa
    04 cr125
    Jets are clean. i moved the clip up a notch. scrubbed the filter. sprayed out the carb just in case. Will get some fresh mix and give her a test run.
  13. Xriderdown Husqvarna
    La Center, Washington
    WR360 SW / WR360 IT / FE501 AU
    BUL MK3,KAW KE100,CZ 988-1,YAM FZ1
    Sometimes jets can appear clean if the measure you are using is seeing light at the other end. They could be restricted and you can't see it by eye-balling them. Just an FYI to consider.
    ray_ray and yzrider like this.
  14. rancher1 Husqvarna
    WA
    I would check the muffler to see if it is saturated / plugged, it can cause a problem like you describe, and it is only a few bucks to repack.
    Motosportz and ray_ray like this.
  15. jimmyjamez12 Husqvarna
    pittsburgh pa
    04 cr125
    the jets were shiny inside. plus i sprayed carb cleaner through them for good measure. the muffler does seem to be wet inside, i assumed from the mix. it is sealed though. stock. can that be repacked?
  16. Motosportz CH Sponsor
    Comp check.
  17. ERIC EDER Husqvarna
    2014 WR 250
    SUPERDUKE, GS 750 CAFE, DRZ 400
    Had the same problem with my 01... repack muffler mine was soaked with oil and water from old owner power washing bike without a butt plug, new packing = less weight+better running!!
  18. jimmyjamez12 Husqvarna
    pittsburgh pa
    04 cr125
    I don't have a compression tester... ok so test ride... putting along and roll throttle..BOG....pull clutch. get some rpm's. slip clutch...ZING ...off like a rocket! grrrr
  19. jimmyjamez12 Husqvarna
    pittsburgh pa
    04 cr125
  20. Tentontimmy Husqvarna
    Caribbean
    2012 WR125
    Suzuki GSX-R1000
    Just a suggestion, the jetting could be lean at a particular throttle setting. You're riding along and the bike is gradually getting starved of fuel. Then when you crack the throttle...BWOOOOH. You get a lean bog.
    Try to identify which circuit in the carb may be lean. If in doubt, try adjusting the needle first as it has the greatest overall effect on running. Drop the clip down the needle to richen the mixture.
