Gasket Or Form A Gasket?
Discussion in '610/630' started by nix296, Aug 13, 2011.
  1. nix296 Husqvarna
    Another noob to huskys with a light weight question.
    Got enough Ks on the new 630 to do an oil change & filter change and clean the screens. The seal between the clutch cover and crank case, is it a gasket (if so, can it normally be reused) or is it form-a-gasket to be redone every dis-assembly?
    Love the bike, love the forum, thanks in advance for your input.
    N.
  2. Up-tite Husqvarna
    reuse it many times , no sealant makes it harder next time then will tear it.
    Later George
  3. jtemple Husqvarna
    Papillion, NE
    2011 TE630
    2013 Kawasaki ZX-14R
    Re-use it? It's a paper type gasket. I have pulled that cover a few times and have replaced the gasket each time. Maybe I'm overdoing it. :)
  4. willie Husqvarna
    NS Canada
    TE 630
    Paper
    Dito for me!
  5. capt42104 Husqvarna
    CenCal
    For those of you cleaning the screens every oil change, are you finding anything on the screens? Mine were nearly spotless clean when i did the 1k mile oil change.
  6. Circus Husqvarna
    San Diego
    The left side screen gets some debris in it, but the right side stays pretty clean. Yes, reuse the gaskets multiple times. My dealer recently worked on my clutch and charged $27 for the gasket -- pretty expensive to replace every time you take off the right side case.
  7. jtemple Husqvarna
    Papillion, NE
    2011 TE630
    I clean the left one at each oil change; it almost always has some junk in it. I have removed the right side one a few times up until maybe 3000 miles on the odometer. Each time, it was completely spotless. I'll check the right side one again the next time I do the valves.
  8. nix296 Husqvarna
    Thanks George. I'm assuming it is a paper or similar type of material.
    On another note, I'm shopping for a skid plate, how can I get one of yours? I around Vancouver, BC
  9. Coffee CH Owner
    Georges website:
    http://www.uptitehusky.com/
  10. Muddy Waters Husqvarna
    On the islands
    So you can reuse it many times but you need to use sealant or else it'll get hard next time and tear?
    Or is it don't use sealant because it'll make it harder next time and will rear it?
    :confused:
  11. jtemple Husqvarna
    Papillion, NE
    2011 TE630
    He's saying do not use sealant. Sealant will make the gasket stick down and you might tear it the next time you pull the cover.
  12. Muddy Waters Husqvarna
    On the islands
    Thanks JT
    Something in the way George word it threw me into a loop which I couldn't decipher...
    :o
  13. highdez1981430cr Husqvarna
    Yucca Valley,Ca.
    How does this sound,
    Use a gasket sealant between the outer case and the gasket and rub grease or oil on the inside case to act as a release agent to help the gasket from tearing.just a thought.
    On that subject,what is the best gasket sealant that you have had the best success with?
  14. jtemple Husqvarna
    Papillion, NE
    2011 TE630
    I pulled my clutch cover for the last screen check and put it back on. No sealant used and I reused the gasket. No leaks.
    I also put a new valve cover gasket on and skipped the sealant. Again, no leaks, and that thing will be easier to deal with the next time I check valves.
  15. deepcdiver Husqvarna
    earth
    OK, I must confess I never looked at the screens on my 610. I am from the "if it ain't broke" school. I mean, the screens are there to catch stuff...great. Do they really catch so much stuff that oil circulation wlll be impeded if they are not
    cleaned? I think of the old sludge traps on vintage bikes, before there were filters, however eventually those were meant to be cleaned. Or do you guys clean the screens out of curiosity of what you will find? I'd rather spend my time checking the valves once every few thou...
  16. jtemple Husqvarna
    Papillion, NE
    2011 TE630
    The left side screen always has some stuff in it at every oil change. It's easy to get to, and a proper oil change on the bike requires cleaning that screen.
    The right side screen is really only intended to be checked at valve check intervals. However, I have yet to find anything caught in that one, even after 9000 miles. YMMV.
  17. Up-tite Husqvarna
    Look at it like it's a fuse on a stick of dynomite. When they are out you can see if something unusual is going on if so cut the fuse before it goes BOOM. Reason for cutting the paper filter apart so can look at the bottom of the pleats to see whats happening before it does.
    Later George
    mekanik likes this.
