125-200cc Gasket seal vforce 3
Discussion in '2 Stroke' started by ripnriding, Feb 14, 2016.
  1. ripnriding Husqvarna
    Kingston, Ontario Canada
    2017 TX 300 and 2010 CR 144
    2007 husqvarna TE 450(sold)
    Winter...removed carb and vforce reeds and going to clean and replace anything as seen that needs replacement. Carb looks great other than gasket ripping at throttle cable plate...probably didnt help that it was minus 30 c yesterday...garage was a taad chilly. Reeds had minor damage....swapped out.
    Question...removing reeds basket to swap out reeds reaulted in a shredded gasket. In reading....seems going with a liquid gasket vs paper gasket best for seal? "Mark" from quadexpert recommends three bond in between carb boot (grabbed a new one as well) to help with seal. Do I need to use paper gasket or anyone just bypass that and stick with a "threebond" liquid gasket?
    Btw...Kudos to Mark from quadexpert....I left his store even MORE jacked to ride this new to me rig this season...apparently the bike has some racing histroy ;)
  2. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    Another method is to use paper gaskets on either side of the reed block, Husky OEM or older Honda CR. Seems to work for me on both WRs, no leaks that I can tell.
    :cheers:
    ripnriding likes this.
  3. ripnriding Husqvarna
    Used a liberal amt of threebond 1184 in between reed basket/cylinder and carb boot/reed basket....feeling pretty confident that this sealed....a slightly iffy moment watching gasket material purging into reed basket but caught in time....lesson learned...a little goes a long way with this 3 bond stuff:eek:
  4. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Ha three bond i used once and it remains slightly prone to fuel when i next tore the bike down there were grey specks of threebone all over my reeds, and a stringy grey on the cage, personally i would use a small amount of RTV silicone and a papergasket any day.
    NCSteve likes this.
  5. NicaJohn Husqvarna
    2004 cr125 02 cr135 02 wr144
    Kdx200,2015 beta 430rr
    Crazy this popped up today as I am in process of tear down and replace top end on my 04 cr125. Does anyone know if you can just replace reeds? If so have the#? Was on mototassinari Vforce site and can't find anything. Would replace whole assembly if that's the only choice. Thanks
  6. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
  7. ripnriding Husqvarna
    Yup paid 86 canadian dollahs quadexpert..part#8000H0477 reeds only
  8. NicaJohn Husqvarna
    Thanks. Pretty sure same bikes but '00-04 all interchangeable? Also any luck with plastic sets or piece em? Seems like just harder and harder to find
  9. DTX915 Husqvarna
    wr125
    kdx200 tt500 yz450 klx125
    store.mototassinari.com
    fantastic service right from Mototassinari
