TE/TC Gear box oil change frequency
Discussion in '2st' started by toolie, Jun 26, 2019.
  1. toolie Husqvarna
    Ontario, Canada
    1986 400 XC, 2018 TE300
    1986 Can-am 250 ASE-sold, 1985 RZ500
    How often are you guys changing your gearbox/clutch oil?
    My buddy is changing his every 3 or so hours!! Is this not excessive?
    I didn't find any reference in the owner's manual. I'm currently at 6.5hrs on my 18 te300
  2. BikePilot Husqvarna
    Golden, CO
    2019 TX 300
    Honda CR250R, Montesa 315R, XR650R..
    It depends a lot on how much the clutch is used. 3 hours of hard-enduro type riding with a ton of clutch slipping or of MX where some riders use the clutch out of every turn would absolutely make sense. For casual trail riding I don't think there is any harm in stretching it to 10 or even 20 hours. If the fluid doesn't get hot or contaminated by the clutch it'll last a really longtime. Using the clutch really aggressively can heat the oil up quickly and also shed some clutch material, contaminating the oil. This all assumes using oe spec oil. Some folks run other oils that may break down faster.
  3. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    If I changed mine after every three hours of riding, it would be after each ride!:eek: I ride a lot of tight single track, so clutching is the norm. I check it to see if it's getting dark, or maybe looks like water has gotten into it ....otherwise, I will change it at least once a year if I haven't been doing that much riding. I use Honda Proline transmission oil.
  4. fletchman45 Husqvarna
    park rapids
    All good answers...I've used spectro 80 wt light viscosity oil for twenty plus years .knock on wood. no clutch or transmission failures..I'm a fairly aggressive old A rider who loves the clutch...I change mine at four hours...five if I'm lazy or don't have time..(no spare bike) three hours if extreme (ie Enduro race). My thoughts are that oil and air filter are your cheap insurance to a long lasting engine..if riding aggressive my oil is dirty at five hours..but I'm sure my slow as heck ..c rider buddy Jim could go 20 hours and his oil would look just as good.. I've used all spectro oils for twenty five plus years..and had great luck..one failed bad from the factory gas gas transmission..one blown up 1993 husky wxe 250..(jetted wrong 25 degrees WOT on tar...my fault) I always have one or two spare air filters and air filter cages..I think I would abuse the clutch less with a 300 just due to the added torque (my bike is a 19 xc 250)..I'll be back on a husky or tm next year..your buddy is more then likely to never see a failure the way he is doing it...if he puts 100 hours on in a year at 10$ a quart..so app 333$ a year and at changing it every ten hours..that's a hundo...so 233$ a year for piece of mind and no worry of failure and I would assume the clutch components would last longer ..I'll stick to my 4 hrs.. a transmission failure would suck ..I'd probably drive 11 hrs one way to have it fixed and lose time and money...my slow buddy changes his once at beginning and once at mid season..however he probably rides twenty hours a year...
  5. ggg Husqvarna
    TE250 14
    NONE
    not racing 20hrs even if was racing its would still be around 8 hrs or until it does not shift as smooth you can tell when the oil lost its slickness
  6. toolie Husqvarna
    Ontario, Canada
    Some good opinions, I do ride a few enduros a year but usually trail riding with buddies. It is relatively cheap insurance so I'll change it sooner rather than later. Based on type of riding I'm doing at the time.
    Thanks All!
  7. Husky_250 Husqvarna
    Finland
    TE 250 2015 and TC 250 2018
    KX 125 1992 and RM 125 1992
    I change my transmission oil every 5-6 hours. I use Bel Ray Thumper Gear Saver 80W-85. It looks good = red when it comes out from the engine, but in my opinion it is good to always have fresh oils. It does not cost a fortune to change oil this often anyway.
  8. toolie Husqvarna
    Ontario, Canada
    That's the oil I just picked up yesterday.
    I'll be about 7-8 in right now.
    Thanks again
