250-500cc Gearbox oil for Husky WR360 ?
Discussion in '2 Stroke' started by EURO1215, Feb 3, 2015.
  1. EURO1215 Husqvarna
    Czech Republic
    WR 360 2000
    Hello, i recently rebuilded my WR 360, and now iam searching for an bottom engine/gearbox oil and iam between those two : 10W-40 (as in manual ?) and 80W-90, i have this one in garage but not sure which would be better for the bike. Thanks
  2. bulto Husqvarna
    2002 cr 250
    ktm maico honda
    Don't use 80w hypoid lube. Use motorcycle gear oil or search what other guy's are using.
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    you need to use an oil that is rated jaso-ma. that means its wet clutch compatible. personally, i use amsoil 10w30 motorcycle oil or rotella white or blue jug diesel oil. these are rated jaso-ma
  4. flyingbob Administrator
    USA
    01&02WR360_02WR250_02CR250_12WB165
    01 VOR400_07 TM450_22 GG250_07 Tuono
    Mobile 1 0w-40 Euro formula is in my 360 gearbox. And in everything else I throw a leg over.
    Tinken likes this.
  5. Petar Husqvarna
    Pernik, Bulgaria
    Wr 300 94
    I recommend ATF Type F and frequently change.
    Miezie666 likes this.
  6. flyingbob Administrator
    USA
    That's what I used before going to Mobil 1 oil. It's hard to get where I live now.
    Petar likes this.
  7. Miezie666 Husqvarna
    Germany
    2x YZ 125, 1x YZ250 2005, XT600 2KF
    I use ATF in all my 2 Strokes without any problems
    Petar likes this.
  8. EURO1215 Husqvarna
    Czech Republic
    WR 360 2000
    Thank you all ! getting 80w90 , not sure about the mark because we have them very different where i live.
  9. justintendo klotz super techniplate junkie
    hopefully your clutch wont slip or chatter
    Husky Gordon likes this.
  10. icebergstu Husqvarna
    South Australia
    WR300/TE610e
    WR360 CT110 XR100
    What does a 4T Husky run in its gearbox and why do you think it would be any different.
    Most Husky 4T share gearbox and motor oil. It circulates through the entire engine.
    Most people use good quality motor oil in their 4T Husky's.
    80/90 will be too heavy to be honest.
    Stu
  11. flyingbob Administrator
    USA
    His bike is a 2T WR360.
    80/90 mineral gear oil
    Kinematic viscosity at 104°F (40°C) 139-cSt
    Kinematic viscosity at 212°F (100°C) 15-cSt
    Non synthetic Type F transmission fluid
    Viscosity, cSt @ 40°C 39.5
    Viscosity, cSt @ 100°C 7.5
    Mobil 1 0W-40 synthetic oil
    cSt @ 40ºC 75
    cSt @ 100ºC 13.5
    Might drag a little. I'd say hard to start in gear at least.
    Tinken, icebergstu and Petar like this.
  12. PowerKord Husqvarna
    Notheast Ohio
    2008 WR 250 Sold
    2014 Sherco SE-R 250
    Another vote for Type-F.
  13. icebergstu Husqvarna
    South Australia
    WR300/TE610e
    WR360 CT110 XR100
    Fully aware that it was a WR360
    Just drawing comparison.
    Used Penrite 5/40 in my 92 360 without issues.
    Stu
    justintendo and flyingbob like this.
  14. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    so question
    besides everyones personal bias, what oils for old school 2stroke gearboxes are truly worldwide
    i have used Torco, BelRay and a few others over the years but seem to be US product
    i have seen oils listed that i have never heard of
    i use Shell Rotella in my diesel pickup (ute to the down-unders)
    never tried ATF type F, but had 2 friends that did with no issues
    been using the all synthetic stuff myself as just the gaskets to pull my engine down on a simple 2 stroke cost more than 8 oil changes
    i replace my all synthetic gearbox oil annually as it seems fine when i do drain it, so 8 years (for me)
    what i was getting at is how little the cost of the oil is compared to hard parts
    back to my original question, which specifically made oils for the 2 stroke gearbox are common worldwide
  15. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Rockoil is what i use
    Putoline
    Shell
    Maxima
    Silkoline
    Castrol ( not sure on spelling)
    These are main brands in uk missed a load im sure but think they may be big enough to be world wide
  16. justintendo klotz super techniplate junkie
    it seems 2premo has a point, each country has a batch of oils. im sure some are rebranded and called something different elsewhere.
  17. EURO1215 Husqvarna
    Czech Republic
    WR 360 2000
    Hello ! got her running today. i used 80W90 thats been laying in garage to clean the engine. now iam gonna put it out and gonna use one from starline, can i use this one ?
  18. justintendo klotz super techniplate junkie
    pretty damn thick oil as been said, no one here runs that thick of oil. try it if you want. if an oil doesnt have a jaso-ma rating, it may make your clutches slip. there are oils that dont have that rating that work, its a gamble if you picked one of those.
  19. Eaglefreek Husqvarna
    Fayetteville,TN
    11 WR300
    Gear oil is rated differently than motor oil and 80w90 gear oil is about the same as 10w40 motor oil and you will be fine. I use cheap ATF and have no issues. I think you could put about any oil in a 2 stroke transmission and be fine.
    shawbagga likes this.
  20. uranys Husqvarna
    Pittsburgh, Pa
    96 xr600r
    I ran atf in my kx250 with no issues but have switched to cheapo rotella 15w-40 in my 360. My only concern about atf was that if a crank seal went it could dissolve the oil that lubes the crank and bearings and cause a seizure.
    Rotella is cheap and works fine
