huskyte610e
I'm having infrequent issues when dropping from 3rd gear down to 2nd gear.
ie: it wont drop down to 2nd, even with a heavy push.
I can get it by going up one, then down two.
It seems to be more regular when the engine is warm, but does not happen at very gear change.
As best i can tell, the old issue with the woodruff key was only on early 06 models, and would have caused obvious other noises first.
I'm thinking it may be the oil.
I used to have trouble finding neutral on my 04 610, until i found a suitable oil that worked.
Could it be oil?, and if so, any reccomendations of oild choice/specs?
Alternatively, could this be something else?
2007 Te-610
David
2007 Te-610
David
