General bearings question... need to find one
Discussion in 'General (Main)' started by Coffee, Jun 17, 2013.
  1. Coffee CH Owner
    I was reading this thread:
    http://www.cafehusky.com/threads/wr-250-bearings.33643/#post-319142
    Which apparently means that bearings have a standardized numbering system, does anyone have any links to places that actually explain how they assign those types of numbers?
    I have a busted bearing off of a piece of equipment, and have been unable to locate it anywhere on the internet.
  2. fran...k. Husqvarna
    eastern ct
    There are lots of kinds of bearings. For a single row ball bearing they go by the bore of the inner part. There are series of duty, light to heavy with the balls being bigger and of course the thickness and outer diameter increasing as the duty rating goes up. There are inch series and metric series. But there are roller bearings, taper roller bearings, spherical roller bearings. needle bearings, and more I could think up and more I couldn't name. BDI is most likely nation wide though the place I used to go in person doesn't have a cash drawyer any more. http://www.bdi-usa.com/ Even Napa employees have the tools to get most bearings though I doubt most know how to use them.
    If you verify it is a single row ball bearing I could elaborate.
    If it is a taper roller beaing often the cone and the cup need ordered seperately. Some things are just kind of special orders by the factory of the piece of equipment perhaps incorporating a seal a special way or a special length.
    Fran
    Coffee likes this.
  3. ray_ray Mini-Sponsor
    The Philippines
