Generic clutch and brake levers and perches
Discussion in 'Vintage/Left Kickers' started by Picklito, Aug 26, 2020.
  1. Picklito Husqvarna
    Washington
    430, 430, 430, ,400, 175
    KTM250xc, KTM500mx, KTM440exc
    What are y'all using for an inexpensive clutch/brake lever set? Want some generics to temporarily run on my 81/82 430's while the 'real' pieces are getting gathered up. Thanks.
  2. Chisler Husqvarna
    British Columbia, Chilliwack River Valley
    2010 WR 300 Husqvarna
    I run the Pro Taper low profile on my bike and I love it .... fully adjustable ... as for the price I didn’t think it was too bad.
  3. Picklito Husqvarna
    Washington
    Ha Ha. Perhaps you have not yet fully realized what a cheap-@$$ Picklito really is? I'm looking at eBay copies. Used to use Sunline but they seem to be long gone.
    Chisler likes this.
  4. ct cr430 Husqvarna
    Connecticut , litchfield county
    1981 cr 430
    2007 honda crf450
    I had a set of “moose “ levers and perched on my cr430 for a while but when I rebuilt the lower end I had a longer clutch arm placed on the engine then had clutch issues . Felt ok when cold but as the engine warmed up had a lot of clutch drag . Placed a magura assembly on the bars for the clutch and back to normal . The moose lever and perch was for a Honda . I do have an extended front brake arm on the wheel for better leverage and the same moose set were ok on that .
  5. Vinskord Husqvarna
    400 CR
    EMGO has a pair for around $20/25. The correct OEM Magura (split perch) run about $80 a pair - new.
    There was an in-depth article in the Husky Newsletters that explained the pivot placement / mechanical advantage / stroke / etc. of a Magura and how many problems that people comment on in regard to bad brake feel and clutch not working can be attributed to levers other than a Magura.
    markt2, DaveM and BadMotoFo like this.
  6. Picklito Husqvarna
    Washington
    The typical Honda/Honda copies are nice, but can be a little short on cable pull for the clutch. EMGO is one I was thinking of but I couldn't remember that name! Thanks.
  7. Picklito Husqvarna
    Washington
  8. redman Husqvarna
    Pa
    77 360 automatic
    ec200 Gas Gas
    they look pretty nice, I like the short levers. Interested in how well they work when installed.
  9. Picklito Husqvarna
    Washington
    I'll post a report. Could have the clutch drag as mentioned above. These are definitely 'ol skool' clutches. If we could install a fishing reel at the end of the cable they'd work great!
  10. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    i have never been able to get cheap lever to work well on the swedes. not enough engagement..
    just run some bark busters and never hurt your mags again
    Saabman82, ajcmbrown and husky jim like this.
