All 2st going from Rotor straight to Coil, to CDI?
Discussion in '2 Stroke' started by 91husky, Sep 8, 2016.
  1. 91husky Husqvarna
    wmx250
    hello all, i have a 91 wmx250, recently i had to buy a new coil and came to find that there are nearly no cheaper replacements than a $100 Refurbished coil or a $50 used one. So, is there a swap to go from Old school to CDI? i have a 3 wire rotor so can i just wire that directly into a cdi and make it work with a cheaper coil ? Any input is appreciated, Thanks
  2. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    which ignition is in it
    pretty sure some had the last of the Motoplat
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    i think he has the motoplat "mini 4"....good luck! the prices the op stated are fair, as they are hard to find. yes you need all 3 components to run
