Just bought a 2007 TE610 with about 1,600 miles on it. I wanted to check the valves as I don't believe the p.o. had done them yet.
I searched and read what I could about the procedure and learned that it isn't nearly as easy as adjusting valves on my TE 250.
I was doing quite well, had the valve covers off and was ready to find TDC.
Anyway, I got careless. I decided to use a small wooden dowel down the spark plug hole instead of the suggested soda straw in order to find TDC. I didn't realize something bad could happen, then voila.... there's now some wood on top of my piston. Something chewed part of the end off the dowel (up to an inch, about pencil size diameter).
There has to be a better way to find TDC that to stick something down the plug hole.....
Can someone explain to me what happened?
Is there likely to be damage?
More importantly, what do I do now?
I assume I will have to pull the head. If so, I'll need some instruction.
Feeling rather stupid about this.
Thanks in advance for any help you can provide.
