GPR exhaust
Discussion in 'TR650' started by bikehunter, Oct 25, 2013.
  1. bikehunter Husqvarna
    Hampshire
    Strada 650
    Harley, bmw, moto guzzi
    Finally checked the DFS tracker and my full exhaust system is arriving next Monday.
    Its a full single set up, will an awsome sound with a good weight saving to boot.:banana::banana::banana::banana:
    Scutler, megatiker75, Toyboy and 3 others like this.
  2. kjackbrown Keep on keepin on.
    Fresno, Ca.
    KLR650
    Sweet! Post up some install pics and review when you get it on :cheers:
  3. bikehunter Husqvarna
    Hampshire
    Strada 650
    Arrived today, and this evening in a very small space in my workshop managed to fit it together!:D
    Getting the old one off was easy, even at the header pipe. What do you do with all the stock parts:eek: , getting a bit full in the workshop as none of my bikes have stock pipes on!
    Some fiddly bits but not too bad and more to be had to see how the cover fitted correctly :rolleyes:.
    Final check and start her up and wow a real bike sound.:banana: As it is now dark here I will ride her to work in the morning and take some pics.
  4. bikehunter Husqvarna
    Hampshire
    Strada 650
  5. bikehunter Husqvarna
    Hampshire
    Strada 650
    Just took this pic but a bit blurred
  6. kjackbrown Keep on keepin on.
    Fresno, Ca.
    KLR650
  7. Clete Husqvarna
    Tigard, OR
    '01 CR/WR 250, '13 650 Terra
    '06 Suzuki SV650 (gone)
    Wish could hear in person, doubt video would do it justice. The overall shape of the can matches the lines of the bike better. Someone probably has already pointed that out....oh well.
  8. kjackbrown Keep on keepin on.
    Fresno, Ca.
    KLR650
    This one gives you a good idea of the single can in action...
    View: http://www.youtube.com/watch?v=sHfti4qBlbc
  9. bikehunter Husqvarna
    Hampshire
    Strada 650
    IMAG0597[1].jpg OK, first day out on the Strada with new exhaust and Hi flo filter. Bike before the added parts was at best say peppy but flatspot at 2000 rpm, stalling when pulling out of a junction which was interesting and a lot of popping due to weak mixture which the Husky mechanic said that people would pay for that noise on a Ducati, HUH!
    To start with a new seat from Concept which added a comfier perch. Next the Eruption which killed all the above and made it more fun to ride and still blasted along at 90+. Then the new filter and finally at the moment the GPR exhaust. Again better and much more controllable at lower revs, like 2000 rpm in top and would pull away smoothly well for a single :thumbsup:.Much nicer sound and its a much better bike to ride as the sound now matches the stroke if you get my meaning!
    The exhaust came with two baffles, one had a smaller end hole but I stuck with the larger one.
    I am very pleased with the build quality and also the fit as you didn't even need to bend and tighten to keep the pipes from hitting the frame etc, all went together well!
  10. Chuffa Husqvarna
    Perth, West Australia
    TR650
    XT250
    Played with camera mounts, so here's another one of the single setup. Rear facing so can probably pick up the sound better.
    kjackbrown likes this.
  11. bikehunter Husqvarna
    Hampshire
    Strada 650
    Now we can say 'they don't build bikes like this anymore' :oldman:
    Coffee likes this.
  12. vodka Husqvarna
    South Australia
    TR650 Terra ABS
    R1200R , Yamy WR250R
  13. Chuffa Husqvarna
    TR650
    XT250
    Just something to watch… This mounting bolt on the exhaust can bounce a bit and bite into the rear side plastic. If this would make you grumble then it might pay to cover the end of the bolt with a rubber boot or work out another solution before you hit the rough roads.
    mario33 likes this.
  14. Toyboy Husqvarna
    Middletown, PA
    2011 TXC250/2012 TXC310, 2013 TR650
    BMW Hp2E/Yamaha Super T/BMW R1200RTP
    Here are a few pics of the exhaust when I first got it. Really good quality, perfect welds. Did not get a chance to weigh it as was in a hurry to assemble and take the bike to Rexxer. Will say that the throttle response was improved. Bike just seemed to have gained in torque, revved quicker. Bike feels noticeably lighter. Well worth the price in my opinion.
      File size:
      156.9 KB
      106
      File size:
      140.1 KB
      102
      File size:
      179.1 KB
      105
      File size:
      159.4 KB
      103
    engineerk9 and bluegopher like this.
  15. bikehunter Husqvarna
    Hampshire
    Strada 650
    Ah yes, already marked it, its not too bad so will put on a protector, thanks for pointing it out!
  16. bikehunter Husqvarna
    Hampshire
    Strada 650
    I can vouch for the above info.
  17. Ogre_fl Husqvarna
    Cook Bayou, FL
    Terra 650
    Tiger 1050
    Damn...that was my first thought too.
    I told myself I would not dump this kind of money into this bike, but I really like the single set up.....crap.
  18. kjackbrown Keep on keepin on.
    Fresno, Ca.
    KLR650
    Same here...just torn between the dual and single still. I'm hoping someone will get the dual setup soon and post a vid of it in action so I can hear more of it before I pull the trigger.
    Anyone here ordering the dual exhaust?
  19. rww Husqvarna
    Kennewick Washington
    tr650
    Ducati, Cagiva Kaw Zuki Honda
    Single looks nice...I'm waiting to hear how the reflash works with the pipe to decide which way to go.....I like the way the 2 pipes look but love the thumper sound and less weight.......
  20. bikehunter Husqvarna
    Hampshire
    Strada 650
    If its any consolation I have been informed that the duel exhausts create torque higher up the rev range and single pipes are at the lower range which is where most of my riding is!
    engineerk9 likes this.
