Grease nipples on rear suspension linkages
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by robertk61, Mar 24, 2011.
  1. robertk61 Husqvarna
    Melbourne, Australia
    09 WR250
    What year did they stop installing these?
    I have a 11' TE310 and it doesn't come with them, but my old 01 WR 250 had them.
    I would grease them every ride as a precaution.
    Has anyone put nipples on new type linkages and if so , is it hard to do?, is there a drilling already through to the top mount so that you don't need one also at the top?
    Also I miss having axle pulls, does anyone make them specifically for Huskys?
  2. Slowpoke Husqvarna
    Southern Ontario
    This thread covers the topic somewhat;
    http://www.cafehusky.com/threads/greased-nipples.16663/#post-146769
    Read the Thumpertalk link. It's not for the latest version of the rear linkage, but will give you a good idea of what's involved. The swingarm pivot is the same however.
  3. ioneater Husqvarna
    NW Texas
    2010 TXC 250
    08 Sprint
  4. Picklito Husqvarna
    Washington
    430, 430, 430, ,400, 175
    KTM250xc, KTM500mx, KTM440exc
    I drilled and installed grease fittings on the linkage of my 09 TE450. Was pretty easy. Still need to do the swingarm bearings, but considering a couple "best options" on how, exactly, to do it. Also switched to new needle bearings with the grease hole where that was needed (lower shock bearing, I think??). Ordered them from a bearing house, was not expensive.
