I saw that the other day. He neglected to include the pressure regulator in his diagram, which is as key a component as the quick release is....
I found this the other day after i had the fuel pump replaced and installed foil back insulation under the fuel tank on MY11TE250...! I hope to keep some of the heat out of the fuel tank, seems to be a factor in these fuel pumps going bad.
