I just had grip heaters installed. Wired direct to the battery, with a small round rocker switch to activate. The switch is in a small metal plate that is bolted to the mirror mount. The wires and switch are exposed at the back and I'm really not happy with the way it looks. It is a 3 position switch, but not illuminated. I'm trying to find something that is handlebar mounted, 3 position(high, low and off), illuminated(so I don't forget to turn it off and run the battery down), and is enclosed and proper looking. Any known options? Thanks!
The POPO of my bike mounted the switch on the back of the headlight pod. Easy to get to. Out of the wind. Concealed wires. Most of the work the POPO did on my bike is crap but this was pretty decently executed. Did require drilling a hole in the back of the headlight pod.
I don't mind drilling a hole if its a clean look. The lighted switch is most important to me if there is one available.
