Guess the part number? Seriously
Discussion in 'General (Main)' started by juicypips, May 12, 2016.
  1. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Hi all as you are aware I've been interfering here for a week or so.. well I'm right into wr250 rebuild and I need the part number(doesn't exist) for the idler mount that's in the case right next to the kick-start gear. 1463122361843-1171796589.jpg
    So if any one has replaced this part, repaired it or started too manufacture more I'm looking for three.
    Will be putting out the feelers and starting my own enquiries for manufacture. Hardened and ground so the needle roller doesn't eat it.
    This bikes a 2001.
  2. rancher1 Husqvarna
    WA
    That part only comes with the main cases. Looks like you are now making your own.
    juicypips likes this.
  3. robertaccio Husqvarna
    San Diego, Ca
    2021 Husqvarna TE300i
    EBAY.............parts engine(s)
  4. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Looked! May look at whole cases.
    An waiting for a few 40x17x8mm bearings to turn up before start sweating.
    Need to get this thing up n running an punted out, looked at getting the nub turned down and sleeved also considering boaring out the gear and turning down nub to stick ball race on it.... not going that route cus the factory Didn't.
    robertaccio likes this.
  5. Up-tite Husqvarna
    Powder weld, bronze bushing in gear.
    Later George
    johnnyboy and robertaccio like this.
  6. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    If I went bronze bushing I would have it fully floating and not bonded to either gear or the stub.
    It may come to that yet.
  7. Up-tite Husqvarna
    Press fit bushing then hone ID for clearance on stub shaft.
    Spiral oil grooves in bushing, will last long time.
    Once set up make several bushings for future spares.
    Later George
    juicypips and robertaccio like this.
  8. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    So got two alum bronze bushes press fitted on the stub (thanks George!)
    And waiting for my crank to come back... sooooo tired of waiting for this bloody crank.
