Handguard LEDs question
Discussion in 'TR650' started by Cyntax, Nov 28, 2015.
  1. Cyntax Husqvarna
    The Netherlands
    TR650 Terra, 900R Nuda
    MG V50 NATO III
    So I bought some high intensity LED bars two weeks ago and I've attached them to my handguards today. In the photo the wires are attached to a spare motorcycle battery I have laying around and I would like to permanently attach them to some switched wire in the headlight housing.
    Has anyone done this before and which wires could I use best for this application?
    PaulC likes this.
  2. 268fords Husqvarna
    Powell, Wyoming
    08' TE510'
    Does your terra have a 3w parking light that comes on when the key is on without the engine running like the TE's have? If so, you could tap into that since they're not pulling much power.
  3. Cyntax Husqvarna
    The Netherlands
    MG V50 NATO III
    Thats a good one thanks, there is a position light on the Terra which I am planning to change to a LED soon too so I will posti tap the handguard LEDs to those wires.
  4. nev.. Terrarist
    Greensborough, Australia
    '13 TR650 Terra
    '14 XT1200ZE
    I've tapped that position light to be the ignition-on relay trigger for my aux lights and my heated handgrips. It doesn't serve much purpose on its own as the headlight is always on. It must be a statutory requirement in some markets perhaps.
    PaulC and 268fords like this.
  5. Cyntax Husqvarna
    The Netherlands
    MG V50 NATO III
    I see, I tapped into the position light yesterday and it works like a charm. Also installed some high reflective tape around the motorcycle and a LED as the position light. I will receive the Cyclops headlight kit somewhere next week so that is also going to be installed asap.
    PaulC, Thumpa and 268fords like this.
  6. Ignaciob Husqvarna
    Tri-Cities, WA
    TR650 Strada --> Terra (aka Noxeema)
    05 Yamaha FJR (x2), 75 Honda CB400F
    I went ahead and ran both set of wires from the battery to the headlight area and installed a relay that I then used the high beams as a trigger. While LEDS are certainly more watt conscious than a typical halogen bulb...I was comfortable just adding to the existing load and risk overloading the wire or a switch.
  7. snail_72 Husqvarna
    Cairns Queensland Australia
    Tr 650 Terra
    KLR 650
    Cyntax and PaulC like this.
  8. snail_72 Husqvarna
    Tr 650 Terra
    KLR 650
    PaulC likes this.
  9. snail_72 Husqvarna
    Tr 650 Terra
    KLR 650
    I taped in to the park light and high beam. for my set up
