Handguard question
Discussion in 'TR650' started by kyle01, Feb 16, 2013.
  1. kyle01 Husqvarna
    Chicago il
    TR650
    Beta 430, Honda CR 144, XS650
    Running renthal twinwalls and can't figure out which hand guards are gonna fit. I like Cycra Pro-bends but do I need the center reach mount or just the standard 1-1/8" mounts? Anyone done this?
  2. Terramack Husqvarna
    Big Smoke, Canukxico
    TR650 terra
    I will answer this one since know one else has piped up so far. I have used protapers 1 1/8 with Cyrca 1 1/8 handgaurds on my last two bikes. Every bar is slightly different but the Cycra kits fits. Sometimes you need to hack the balls off of your levers are find shortie levers.
    Does this help?
  3. kyle01 Husqvarna
    Chicago il
    TR650
    thats what i was looking for, i don't need to know if it's a perfect fit- i just need it to be in the ballpark.
  4. mario33 Husqvarna
    Warsaw, Poland
    Dont like cutting any of my balls off so Cycra is not for me... AFAIK two producers are doing it right for such large levers - Barkbusters and ZETA Racing.
    Going to pair Renthal Twinwalls with Zeta hbars/XC shields. Red is the colour anyway :)
    kjackbrown likes this.
  5. Terramack Husqvarna
    TR650 terra
    That being said about shortie levers, I noticed that ASV list levers for Husky, We need a investagate the possibility they may fit.
  6. Toyboy Husqvarna
    Middletown, PA
    2011 TXC250/2012 TXC310, 2013 TR650
    BMW Hp2E/Yamaha Super T/BMW R1200RTP
    Really like these MSR guards that are cheap and work well with the BRP mounts to the top of the bar. These worked just fine with Motosportz handlebar risers. THE plastic guards can be purchased separately in white black or red.
    FabOneUp and Kenneth Webb like this.
  7. Kenneth Webb Livin' It Up!
    Tucson AZ
    TE630 TR650 Terra TE310R
    Like those guards. Some of the same features of the HDB setup and I'm sure for less dollars too. Going all the way to the bar clamps is the way to go.
  8. Toyboy Husqvarna
    Middletown, PA
    Thanks Ken. Was pretty inexpensive, The guards were 35, the BRP mounts around 40ish and the black mud guards not pictured were 20. Really strong, nothing moves. Got finished install pics at home, will load up tonite.
  9. Terramack Husqvarna
    TR650 terra
    Where did you find the BRP mounts?
    thanks
  10. Kenneth Webb Livin' It Up!
    Tucson AZ
    Be careful on sourcing shortie levers. When I was fooling around with my HDB mounting I looked for some, everywhere I could think of. Look at your stock levers and note that the "jog" around the switches is exceptionally long. If it isn't, the lever will hit the switch assembly and not give a full pull all the way to the grip. Looking at my WRR and TE, their levers would never work. I couldn't fine anything on line that looked like it would work the same way as the stock Magura levers. At least I think it's Magura from the symbol stamped on them.
    If anyone finds an alternative, please post up!
    FabOneUp likes this.
  11. Toyboy Husqvarna
    Middletown, PA
    Got those from my Husky Dealer "Toytech" in Grantville, PA. 717-469-9484 if you want to call them or I can ask him where he sourced from and post.
  12. Terramack Husqvarna
    TR650 terra
    i found them on BRP mounts on their website. They sell for over $60. By the time I get them shipped to Canada it would be more like $80.
    If I could find a deal like you I would buy some.
    Thanks
  13. pvduke Husqvarna
    ... on the gas...
    tripple-hondo hoosk...
    short levers: make your own, snip the ball off, trim to size, weld the ball back on. easy-peasy.
  14. kjackbrown Keep on keepin on.
    Fresno, Ca.
    KLR650
    But ones like these look soooooo much cooler :thumbsup:
  15. Toyboy Husqvarna
    Middletown, PA
    Call Scott at Toytech. He discounts and would probably ship to you. He is a good guy and will go the extra for you. He is within walking distance of the post office.
  16. FabOneUp Husqvarna
    Pikes Peak, Colorado
    '13 TR650 Terra
    '14 KTM 450 XC-W '11 BMW R1200GS
    Easy-peasy! I cut mine off to mount my Cycra hand guards with no hesitation and actually like the feel without the balls. Why, if you have hand guards, is the ball even necessary? If you don't have guards, I understand you don't want the lever going through your leg or something. But if you have guards, does it really matter?
  17. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    not for bike service tests in the uk its not, i cut to fit and round the ends with file, happy days.
    love the plain metal look of guards but one down and they look trash.
  18. pvduke Husqvarna
    ... on the gas...
    good point. but the other day i lowered mine to the gound softly with the clutch in and no ball w/ just hand shields on a muffed step-up i didnt clean and i didnt get chopped but it coulda been ugly cuz the grip went in the rocks etc. getting the lever though the back of ones hand in the middle of nowhere could be dicey it soooo not worth it. weld the ball back on is my advice, every time.
  19. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    pvduke, those are open ended guards yes?, i wouldnt cut ball off those just the fully encaged ones you know full wrap around.
    sounds like you coulda done some damage, hope bikes good
  20. pvduke Husqvarna
    ... on the gas...
    copy on the wraps. it was, too. the barky is thin enuf to go sink in soft stuff, tweenst rocks etc...
    pfft- bikes good. it was an oh sht, oops, blew back tire off pull cl in lower her down easy spin around and do over.
    im fine too thanks fer askin! :p
