TE/TC Handle bar dampening
Discussion in '2st' started by HS507, Feb 20, 2018.
  1. HS507 Husqvarna
    NE Ohio
    Te 300
    Yz450,crf150r,crf100f,crf50f
    Have any of you riders tried using a kit for the bolts or trip tree for vibration dampening to reduce hand fatigue? If so what brand or recommendation? Im starting to consider. I dont mean steering damp either
  2. Teambowles Husqvarna
    NorCal
    19 FE501
    19 ktm 6 days excf 450 n excf 500
    Try bykas.com I think he's still making them. And yes huge difference
  3. robertaccio Husqvarna
    San Diego, Ca
    2021 Husqvarna TE300i
  4. silverstreakNZ Husqvarna
    Christchurch nz
    82cr500,76gp360,90wr250,81 420AXC
    74 tm400 , 02 gasgas ec 300
    You can fill the ends with lead shot using wooden/plastic Dowell to contain it
  5. robertaccio Husqvarna
    San Diego, Ca
  6. silverstreakNZ Husqvarna
    Christchurch nz
    That's a pretty decent idea . Never seen them before
  7. jsromeo288 Husqvarna
    510smr TE300 701 @2smoke_romeo ig
    Flexx bars!!! They are amazing! A must if you have broken both your arms like me.
  8. robertaccio Husqvarna
    San Diego, Ca
  9. robertaccio Husqvarna
    San Diego, Ca
    [R DAMEDIf you want t really get wild. $$ go for those air damped spring setups that some of the pros are using.
  10. John Bunker Husqvarna
    Mid Michigan
    TE150 2017
    XR250 Honda 1985
    NH-JP likes this.
  11. NH-JP 2nd Fastest Old, Slow Guy!
    New Hampshire
    2017 TE300
    1988 Honda Hurricane,
  12. pvduke Husqvarna
    ... on the gas...
    tripple-hondo hoosk...
    make a bar snake......close fitting fuel hose, fill with silicone, snake it through, plug the throttle tube end w/ a hot glued cork tapped in past flush (recessed). cheap n easy, no parts to wear out/replace and it works.
  13. fletchman45 Husqvarna
    park rapids
    Ironically and strange enough the tc 250 motocross bike comes with rubber mounted bars while the enduro comes with solid mount...
  14. Norman Foley Husqvarna
  15. Picklito Husqvarna
    Washington
    430, 430, 430, ,400, 175
    KTM250xc, KTM500mx, KTM440exc
    One ride on the new Xtrig mounts says they're good.
  16. eddychecker Husqvarna
    Sycamore, IL
    2011 TCX250 & 2013 TE300
    2008 KTM 450XCW
    I have a deteriorated CMC joint at the base of my right thumb that makes riding painful. The Flexx bars have given me back my riding. I love them and recommend them to everyone because it takes most of the shock out of your hands.
    robertaccio and Norman Foley like this.
  17. taps Husqvarna
    TX
    '94 WXC360
    '15 RMZ450, '08 RM250, & '74 MX360
    I have xtrig phds on my rmz, and I can't say I actually notice much difference. Then again, I'm slow, and I'm using the yellow rubbers. Seems faster guys notice a difference with those, and slower guys tend to like the green. Heard some fast guys complain that the green feel too disconnected.
  18. robertaccio Husqvarna
    San Diego, Ca
    Another good thing about the Fasstco Flexx system is that you can mix and match polymer dampers among 3 hardness's and well as adjusting the screw for preload on the dampers.
    eddychecker likes this.
  19. Downhill502 Husqvarna
    Fredericksburg,Va
    19 TE300i
    KTM 1190 ADV R
    I have run the PHDS system with green elastomers on both my FE501 for over 8,000 miles and now my 19 300i and it is fantastic. I actually tested this back to back with the Fasst bars but could not get use to the change in handlebar angle when landing hard. They are both equal in the amount of vibration they remove so pick your poison.
  20. buttstock Husqvarna
    NorthWet Oregun
    2013 Husky Strada
    2014 GasGas 300XC, 2002 Rokon
    Hell, just fill the handle bars with silicone and be done with it. Doesn't weigh as much or cost as much, but it works. Secret instructions available.
