HARD starting & fan runs all the time
Discussion in '610/630' started by KLOC, Nov 8, 2011.
  1. KLOC Husqvarna
    Edmonton, Alberta
    My TE 630 has just started experiencing the HARD starting thing.
    The bike turns over just fine, has 0W40 Lucas Motorcycle Synth in it and no warning lights.
    The fan is running as soon as I get the bike bike fired up and idling; it's 0 degrees Celcius in my garage.
    Do you think the temp sensor would be the culprit?
  2. Ex HVUK Husqvarna
    England
    None
    Yep, unless its a wiring fault to the sensor but that would be unusual.
    Dave
  3. RDTCU Husqvarna
    '11 630SMS
    Yep, and that would explain the hard starting too, no cold-startup enrichment. Have you tried using the little "choke" (cold start) lever over the clutch?
  4. KLOC Husqvarna
    Edmonton, Alberta
    Thanks Gents! The enricher lever actually makes the bike harder to start.
  5. HuskyBrutha Husqvarna
    SM630
    690 R, 500 EXC, XR250
    Hard starting can be fuel pump not primming up to the required pressue.
  6. Redback Husqvarna
    Trondheim, Norway
    Sounds like the temp sensor is broken and giving wrong feedback to the system. A friend with same bike SM 630 had the same problem, fan ran as soon as ignition was switched on, and the bike was hard to start when cold. As soon as he ( and I ) got the tempsensor replaced, everything was as it should be.
  7. Ketek Husqvarna
    Germany
    Had that problem too.. it was a broken temp sensor. :o
  8. KLOC Husqvarna
    Edmonton, Alberta
    Thanks Gents! New sensor is on its way.
