Has anyone tried running EFI software from a Netbook?
Discussion in 'EFI/carb' started by krieg, May 27, 2010.
  1. krieg Husqvarna
    Matthews, NC
    Many in the past
    '12 Triumph Scrambler
    I'm thinking about trying iBeat on one of these teeny little "Netbook" laptops. You know, the ones with 10 inch screens, N450 ATOM processors that run about 1.6 Ghz? They weigh about 3 lbs and will fit in a hydration backpack. They also run about 8 hours on a full charge.
    Anyone ever try one yet?
  2. glangston Husqvarna
    2012 Husqvarna TE 310
    2012 BETA 350 RS
  3. ioneater Husqvarna
    NW Texas
    2010 TXC 250
    08 Sprint
    The netbooks I've read reviews on don't have cd/dvd drives. Not enough room physically. May be able to rip the iBeat disc to a USB stick and install that way, not sure how locked down the install discs are. Also, sounded like folks were having issues with W7 64 bit not liking iBeat. 32 bit didn't seem to have probs if I remember the thread right.
    Netbook sized computer would be perfect for taking along on the ride and experimenting with settings.
  4. Coffee CH Owner
    If a netbook has a usb port I would think and external dvd/cd player could be used to install the software.
    You could always buy a netbook from somewhere that has a reasonable return policy in case it did not work.
  5. seymore Husqvarna
    Boise, ID
    I haven't tried yet, but I don't see why it should work as long as it doesn't Linux. Many of the Netbooks I looked at run either XP Home or Win7 Starter which are both 32bit. The iBeat CD is only 115MB which should install OK from a USB drive.
    You could probably take iBeat loaded on a thumb drive to a smaller computer shop that would allow you to try loading on a Netbook. Take the EFI USB interface with to see if it reads the port OK when it starts up.
    Ive seen many of these Netbooks for $250.
  6. nocontrol Husqvarna
    Fullerton, CA
    Should run it just fine, I run the powercommander software on mine, along with other much more intensive programs.
  7. bigcahunak Husqvarna
    Israel
    It worked fine on a small Asus here, and you dont need any CD/DVD drive. Use any other desktop computer to copy "DiagnosticTool2.00_English.msi" (about 23mb) from the ibeat CD to a USB stick.
