Have lighting kit, need wiring diagram :)
Discussion in '4 Stroke' started by Sandgroper, Mar 20, 2010.
  1. Sandgroper Husqvarna
    Dubai
    Just purchased a aftermarket headlight and tail light for the 510TXC.
    Anyone know where I can get info on wiring it up?
    :notworthy:
  2. AndrewS Husqvarna
    Niagara Region, Ontario, Canada
    2015 FE350s 2013 TE310R
    2009 TE250 (sold)
    Do you mean a specific diagram for the lighting kit you bought, or do you just want the '09 TXC wiring diagram? If the latter, it can be found in the owners manual. If you don't have the owners manual, let me know and I'll post a copy of the diagram for you.
  3. Sandgroper Husqvarna
    Dubai
    I think i have a wiring diagram but to be honest I havent got a clue on how to wire it up to anything other than the battery with a switch for both in between.
  4. AndrewS Husqvarna
    2009 TE250 (sold)
    Ahh, okay. I'm not really sure how you would do it.
    Did it come with a regulator? Actually, since you have a battery, I guess you have the e-start kit, so you would already have a regulator.
    I would e-mail or call the manufacturer of the lighting kit.
  5. Sandgroper Husqvarna
    Dubai
    good thinking. dont like my chances of getting reply but lets see. Otherwise its back to basics and connect it to the battery with a relay and switch
    thanks
  6. Phoenix Husqvarna
    Oklahoma City, OK
    2009 TXC 450
    2 Ducs, 14 GG 200, 13 Husa 300
    Just hooked up lights to our TXC. Under the tank is a convenient empty plug with three wires...red, yellow and blue. Blue is ground. Red is 12V that is backed up by the battery. Yellow is 12V that is regulated but not battery. If you want to be able to run the light with the bike off, hook your power wire up to the red...but you'll need a switch to turn the light off. If you want it to only run with the bike on, hook it up to the yellow. Connect the ground wire from the headlight to the ground wire on the bike (blue). I'm no electrical expert, but that's what worked for us.
  7. glangston Husqvarna
    2012 Husqvarna TE 310
    2012 BETA 350 RS
    I saved this from the info on installing the tail light from the kit with the 2008 TE's.
    If using the rear light that came with the power up kit it goes like this,,,,or this is what you'll need to get it all wired up. On the connector on the bike the wires go like this.....the red with the black stripe is the + for the right turn signal..... there is no black wire.... the blue wire is the ground for all the lights including the turn signals.....the lite blue is the + for the left turn signal....the yellow wire is for the running lights....and the green wire is for the brake light....
    Now for the light itself......the red wire is the brake light.....the black is the ground..... and the yellow is the running light..........this info is from an 08 TE450...
    Edit...I used this to install mine, so it works for 2008's for sure.
  8. Sandgroper Husqvarna
    Dubai
    Great guys, thanks for thhe tips. Hope to have it sorted soon :)
    Cheers
