Headlight feels hot, new bulb....
Discussion in 'TR650' started by TerraCzar, Jul 27, 2014.
  1. TerraCzar Husqvarna
    Ramona, CA
    2013 TR650 Terra
    Hey guys I put a new Silverstar Ultra in, and the light feels hot to the touch. Do you think I will melt the housing?
  2. BadMotoWeazal Husqvarna
    Alabama
    Check the wattage of the new bulb.... It maybe more than the stock unit was. If so it's burning too "hot"
  3. TerraCzar Husqvarna
    Ramona, CA
    2013 TR650 Terra
    12v 60/55 Watt. It's a 9003 H4 if that makes a difference?
  4. BadMotoWeazal Husqvarna
    Alabama
  5. Tom Ruxton Husqvarna
    Suzuk.Yamaha.Honda.BSA
    only so long as it is a "safe for plastic lens" need to be uv cut.
    Tom R
  6. RidingDonkeys Husqvarna
    Paso Robles, CA
    TR650
    TerraCzar, a few of us have gone a different route that may fix your problems. Cyclops is making an H4 LED bulb that fits into our housing. Baddrapp and I are both using it, and I think a few others. More light output with less watts and less heat. Both of us seem to agree that we're losing a little light to scatter on the high beam function, but the low beam LED is really as good as the stock high beam. The bulb is only $60 and should last about as long as the motorcycle itself. Keep in mind, this is a full H4 replacement, including a diode fan and H4 plug. This is not a cheaply made product at all.
    http://www.cyclopsadventuresports.com/3600-Lumen-H4-H6M-LED-Headlight-bulb-_p_83.html
    There may be more people entering this game of LED H4 bulbs. I had a long conversation with the Twisted Throttle guys at RDV this year. Adam was testing an LED H4 bulb for another company. We compared them, and both seemed to agree that the best solution would be a cylindrical LED where the low beam is near the base and the high beam is near the tip, both wrapping entirely around the bulb. He was going to make that suggestion to the company for which he was testing.
  7. Riding Again Husqvarna
    Palm Coast, FL.
    2012 TE511
    Sold TriumphTiger800xcx, TR650 Terra
    I have watched the threads on this and see this is a very cool option for headlights!
  8. Glengemen Husqvarna
    Las Vegas NV
    Yamaha Raider 1900
    +1 for the cyclops bulb.
    I'm out in the desert at night and this bulb is great. It is not my only light source, but it is a huge improvement over stock. I'll be buying another for my Yamaha Raider.
    Also regarding the Silverstar, I wouldn't use it as there is already an account on this site of the headlight being damaged by bulb heat.
  9. TerraCzar Husqvarna
    Ramona, CA
    2013 TR650 Terra
    Thanks for the LED info, so far so good on the new bulb, no melting plastic after several hour long runs.
    I don't know if I bought the "safe for plastic lens" version or not.
