125-200cc Headlight wiring
Discussion in '2 Stroke' started by Mr_Beat, Oct 10, 2011.
  1. Mr_Beat Husqvarna
    I have a 2006 wr125 with headlight but I am not sure how to wire it. No pc right now to look at the manual if it says anything. I have a yellow wire from the regulator and a blue wire. The large bulb has 3 wire leads?? Which is which?
  2. Harbinger Hróðvitnir
    Tromsø, Norway
    2013 Nuda 900 R
    Buell
  3. hogwackr Husqvarna
    pennsylvania
    18 TE 250
    13 HD Street Glide
    You will hook the blue wire to the right post (when looking at the back of the light) the yellow will go to either of the other two. (dual filament bulb) just see which beam you like better.
  4. hogwackr Husqvarna
    pennsylvania
    18 TE 250
    13 HD Street Glide
  5. motomaniac Husqvarna
    Kamloops BC Canada
    2010 WR300
    2009 RMZ450 2005YZ250 2001 EXC300
    The yellow wire is for your lighting and accesseries. Your light has high and low beams. Run the yellow wire to just one of 2 parralel prongs (walls), the one in the middle (roof) is for ground, you can just ground it to the upper triple clamp where your number plate bolts in.
  6. motomaniac Husqvarna
    Kamloops BC Canada
    2010 WR300
    Its just that simple.
