Heads Up: Fork Cap Screws (Rebound) broke
Discussion in 'General (Main)' started by dartyppyt, Sep 14, 2009.
  1. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    My bike (08 WR250) has been sitting for 4-5 months and bet only have 3 trail rides on her this year. About a month ago, I went to click the Fork Cap rebound clickers and the side of the brass screw broke off. Now I have no way to adjust them. Then like a dummy went to click the other side and same thing happened. They were originally on the 6th click. From the bike sitting they got corroded and siezed up. I called the shop and they have seen it happen on older models. Guess the brass, aluminum, o-ring get corroded. There might have been some water sitting in then after the last time I washed it. New caps are around $83 a piece. Next time I let the bike sit I will shoot some WD40 in the top to keep them wet. I printed off the Marzocchi manual and noticed an allen screw/spring/ball bearing under the cap. I backed out the allen a little so I could turn them.
    Hate to see this happen to anyone else!:banghead:
    Thanx
    Typpyt
  2. Coffee CH Owner
    Thanks for the heads up.
    I just took a look at my 2006 TE250 and it indeed has a brass screw into aluminum, but mine still turns fine. Is there something different about your forks design that may have made it more susceptible to the screw seizing up?
  3. HuskyMax Husqvarna
    WV
    I had the same thing happen on my old 360. But you could buy the screw seperate for like $8. It had the same setup as what you were talking about in the marzocchi manual.
  4. ghte Husqvarna
    Bright, Victoria Australia
    Ths for the heads up-this will qualify for what I did on my husky today.
  5. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    I think that the last time I cleaned my bike, there must have been some water in around the screw and the aluminum cap. From sitting it must have corroded and seized. The dealer did say that I was not alone and has seen this happen.
    The next time I will use air to blow the water out and shoot some WD 40 in it. I also might try some anti seize around the screw and try to pack it in the area between screw and aluminum.
    HuskyMax: Where did you get the screws? The dealer told me that I had to buy the whole cap. I would think that they are just pushed in with an o-ring to seal them off.
    I just purchased a horse for my wife for our anniversary and it has a screw loose!
    Typpyt!
  6. HuskyMax Husqvarna
    WV
    Correct. I have my old one somewhere, I will try to find it and take a picture. I took a piece of brass and threaded the end, then drilled and tapped the adjuster and loctited the two together.
    I ordered mine from Ridersville cycle. http://www.ridersvillecycle.com/index.htm
  7. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Looks like I am now fixed. Talked to Fran @ Bottones(ACE, Great Customer Service). He only showed the caps as being available but recommended that I call Marzocchi before purchasing them @ $83 a piece.
    I talked to a Mike @ Marzocchi USA (Great Customer Service). He faxed me a schematic of my forks and guess what? The rebound screw with an o-ring is available. So for a large some of $22.00, they are in the mail. It is recommended that they are installed with a little anti-seize lubricant or grease.
    Also, I will be shooting a little WD 40 around them especially after washing the bike.
    Thanx Fran and everyone else for your help! Saved about $140.00
    Will let you know how the install goes!
    Typpyt
  8. HuskyMax Husqvarna
    WV
  9. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Excellent pointer!
    I do not want that to happen again. I tore the caps apart last night.
    Those brass rebound adjusters thread up in the cap with an o-ring on them. I had to really work at turning them out without damaging the aluminum. You should have seen all the crud down in them and it is no wonder why they siezed up. I also hit the inside with some 600 grit sand paper to clean up the hole it turns in. I will definately use anti sieze when re-assembling. This is going to become part of my annual go through in the winter. I will put the adjusters back in and tighten the allen screw just enough to make it click just right.
    Hope everyone reads this because it seems to be an issue.
    Thanx Typpyt
  10. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Team,
    Got my rebound adjusters last night from Marzocchi and I installed them. I made sure I coated around o-ring with anti sieze compound and will definately hit them with air gun/ shoot them with WD40 after each wash. I took real care when adjusting the allen set screw against spring and bearing. They work great and In fact better than what you could originally turn them. Thanx for all the advice! Back In Business Again! Hope this is doesn't happen to anyone else!
    Typpyt
  11. 7point62 Husqvarna
    Southwest England
    2004 TE450
    2001 Kawasaki TR250
    Glad you're running again.I guess this is a lesson to all of us that only ever have to touch our adjusters infrequently. All mine moved ok last week but I'll make an effort to give them a squirt of WD and a rotation out and back whenever I remember.
