Heads-up: rear brake
Discussion in 'TR650' started by Ziggy, Nov 21, 2017.
  1. Ziggy Husqvarna
    Melbourne, Australia
    Terra 650
    Just a warning. On my machine the spring split pin holding the brake pads pin in place disappeared somewhere along the road. The pads pin is an interference fit and fairly tight but you certainly wouldn't want it to go west as well.
  2. sussurf Husqvarna
    Port Macquarie area, NSW
    Triumph Sprint 1050, Daytona 955i
    Was your pin tie wired?
  3. Ziggy Husqvarna
    Terra 650
    It is now.
    Split pin is standard.
  4. sussurf Husqvarna
    Mine came new with the split pin installed and tie wired to the brake line.
    Note that it is not necessary to cut the wire (as I did) to remove the clip to change brake pads.
  5. Ziggy Husqvarna
    Terra 650
    Curious. It's not shown in the manual
  6. sussurf Husqvarna
    maybe the dealer did it when he assembled the bike.
  7. Ziggy Husqvarna
    Terra 650
    Must've. Probably seen them go west.
