125-200cc Heads Up!
Discussion in '2 Stroke' started by dartyppyt, Apr 1, 2011.
  1. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Anyone converting from the WR 125 ignition to the CR Ignition. Watch your base gaskets. I did both 125's and both bikes pushed the base gasket out in the back of cylinder shortly after installing the CR ignition.
    The first one, I had to take apart. Clean the surfaces with contact cleaner, put a new one on with no adhesives (Dry)/retorqued to specs. No problems since, it's been fine.
    The second bike, I noticed some pinging and a lean idle last night. I looked at the cylinder base and bingo, it is starting to come out. It was installed, clean, dry, no sealers as well.
    Go figure?
  2. Last Lap Husqvarna
    West Creek, NJ
    What does it cost to convert the ign? And what's the parts list?
    Jeff
  3. wallybean Mini-Sponsor
    Montana
    Darin,
    Thats interesting. I haven't seen anything like that on mine but there isn't the same pressures at my altitude.
