About 500km after new, I noticed I had lost one of the rubber stoppers on my exhaust which stop the heat shield from melting onto the pipe, because my heat shield was melting onto the pipe. This is the rubber stopper which should live on the bracket on the pipe and stop this from happening and this is where the stopper shears itself off. I found this bit sitting in my driveway this week, abut 5000km after the first one broke off. I employed the same solution I have for the other side which has now been in place for 6 months and no ill effects An M4x30 bolt, this one has a philips head, and a few nuts. screw a couple of nuts on the bolt, then put it through the hole and a couple of other nuts on the other side, and a bit of loctite and bobs your uncle. Factory solution My solution
