Heated Grips
Discussion in '610/630' started by MasterChief, Jan 13, 2009.
  1. MasterChief Husqvarna
    Whidbey Island, WA
    2013 TE310 2008 TE610
    Yamaha SRX600 & XT225
    I'm installing heated grips on on my 08 TE610 and was wondering where the best place to tie in for power is?
  2. jwfoulk Husqvarna
    I've heard of a few people tieing in behind the headlight. Just make sure that its not a constant power wire you tie into and that it turns off with the key. Let us know how you make out as I have a set here waiting to go on.
  3. Nesbocaj Husqvarna
    I would: Mount a relay next to the headlight, trigger it off of the light,
    and run a line off of the battery through the relay to the grips.
  4. Fritzcoinc Husqvarna
    Cypress, Texas
    +1. Wire that high of a load directly to the battery.
  5. MasterChief Husqvarna
    Whidbey Island, WA
    For power I tied in to the brown wire off the ignition switch. It powers the taillight and is only on when the bike is running. I grounded them to the ground wire (blue) fron one of the turn signals. I am using the Moose ATV grip heaters at 36watts they are not a very big load. I did put a 5amp ATM fuse in line from the power. If something shorts the grips that fuse will blow and save the brown wire circut.
  6. Pretty similar wiring set-up which I did for my KTM.
