HELP 06 SM610 quits when warmed up:
Discussion in '610/630' started by larry belli, Sep 5, 2013.
  1. larry belli Husqvarna
    Pittsburgh, Pa
    06 SM610
    09 Triumph Street Triple & HD XL883
    Fires up like it should, runs great, I mean really strong, but after I ride for half an hr or so, it shuts down, I mean like a light switch. Start it back up, it runs for about 15 sec and it shuts down like turning off a light switch. The next day it will fire right up and run great. After about 15-20 mi it happens all over again. It's not overheating. Any help would be greatly appreciated.
    Thx
    Larry
  2. jtemple Husqvarna
    Papillion, NE
    2011 TE630
    2013 Kawasaki ZX-14R
    I wonder if it is some kind of electrical problem that is triggered by heat. Like a bad relay?
  3. larry belli Husqvarna
    Pittsburgh, Pa
    06 SM610
    I'm thinking something along those lines. I just hate the thought of paying for hours of service and fixing multiple things before it can be found.
  4. 1lunger Husqvarna
    Bloomfield CT
    Check the wires that run down the frame by the header. If they don't have heat tape, they can melt.
  5. larry belli Husqvarna
    Pittsburgh, Pa
    06 SM610
    Thx 1lunger. Will check that out. I'm pretty sure it's electrical.
  6. jtemple Husqvarna
    Papillion, NE
    2011 TE630
    I know that's true for the 630; wasn't sure about the 610. I have pics of mine before/after heat shielding.
  7. jtemple Husqvarna
    Papillion, NE
    2011 TE630
    Here:
  8. larry belli Husqvarna
    Pittsburgh, Pa
    06 SM610
    My wires are all in tact. They run up the inside of the frame tube, away from the header. Thx for your input.
  9. Stroker Ace Husqvarna
    gas tank vent???? vapor lock??? Try running it with the gas cap loose...
    JonXX likes this.
  10. 1lunger Husqvarna
    Bloomfield CT
    I bet that's it!
  11. 1lunger Husqvarna
    Bloomfield CT
    If it is a vent, get one of these. [IMG]
  12. larry belli Husqvarna
    Pittsburgh, Pa
    06 SM610
    I'll give it a try. Thx for the input
  13. larry belli Husqvarna
    Pittsburgh, Pa
    06 SM610
    It's been raining all day. Will try tomorrow. But why would it just start doing it now? I don't doubt you, but just asking.
  14. maxyb Husqvarna
    Adelaide, Australia
    TE630, classica 105
    CB350, CD90z
    Could be a bit of crap in a vent line; mud, wasp nest, etc. or a vent line could be pinched
  15. larry belli Husqvarna
    Pittsburgh, Pa
    06 SM610
    Well, I tried what you have suggested and I do believe you were right. I think the problem has been rectified. I'll know more after I put a few more miles on it.
    Thx for all your replies !!!
    JonXX and jtemple like this.
  16. R_Little Husqvarna
    NJ
    I currently have the same situation with my Yamaha Wr400....I found 2 clogged carb vent lines...I hope it runs good now that I cleaned them.
    JonXX and larry belli like this.
  17. JonXX Administrator
    Bill's Motorcycles Plus
    360CR 360WR SM610 TC450 TXC250 TC250
    Hondas, Harleys, Yammys & a squid
    Glad you appear to have it sorted, never underestimate the power of a vent line! We had that problem with one of our diesel tractors, it would lose a lot of power and start smoking after running for a while (we bought it SUPER cheap because the guy thought it needed an overhaul). After we had it for a week, I went to fuel it up one day and the fuel cap was near impossible to take off, when I did there was a loud "whump" sound and I felt wind rushing INTO the fuel tank for a second. Turns out, the only problem with that tractor was that it had a non-vented fuel cap on it!
    larry belli likes this.
  18. larry belli Husqvarna
    Pittsburgh, Pa
    06 SM610
    I unclogged the vent hose and it's running beautifully. It's running so good that I run her everywhere. Back pack it to super market, just about anywhere and everywhere.
    JonXX and rajobigguy like this.
  19. cjoecruz003 Husqvarna
    Vacaville, Ca
    2006 SMR510
    So this happened to me just yesterday! Started the bike n my low fuel light was on. I usually have about 15-20 til it's actually empty. Rode 2 miles and it died. Tried starting had a good crank but just didn't fire up. Pulled the enrichment n tried and nothing. I gave it a little gas while starting still nothing. Idk if it was flooded w gas but it was blowing out white smoke. Instantly though maybe coolant or oil leak in the combustion chamber and I need new rings!
    I trucked it home put a gal of gas in and the tank was under a lot of pressure. When I took the cap off it vented more than ever. Ran it for a few minute through the RPMs and seem fine. No white smoke. I need on of those shorty gas cap vents.
  20. larry belli Husqvarna
    Pittsburgh, Pa
    06 SM610
    Glad it was an easy fix and no ring problems. That's gotta be a big relief.
