HELP! 08' TE610 Acting up
Discussion in '610/630' started by MrBob, Aug 27, 2013.
  1. MrBob Husqvarna
    2008 TE610
    DRZ400S
    Hello CH members!
    First off, I'm obviously new here. Bought an 08 TE610 recently and its started to give me a bit of trouble today. I've looked around the interweb and I've got a lot of good info but I'm hoping for some extra help. Here is the deal...
    I noticed the neutral light would blink on and off a few times. Some days it would, others it wouldn't. I checked around and it appears it could be the switch itself or an actual FI malfunction but I ignored it because the bike was running fine.
    But then...this afternoon I took the bike for a ride. Started fine, no problems and ran perfect. Stopped it and went to workout. When I turned it on again the neutral light was blinking while in gear and solid then blinking while in neutral(like the manual states). Then the bike started backfiring and running rough at low rpm. It even stalled on me! Then I noticed the cooling fan turned on, then off. I haven't had too much seat time on this bike but it seemed like it was overheating. The clutch and stator cases felt really hot to me.
    So reading a bit on the internet I did the following;
    -checked H20 thermostat, read 1.5k at luke warm temp.
    -ordered 2 replacement thermostats just in case
    -checked coolant level (was topped off)
    -checked as best I could for frayed wiring.
    My questions are; am I going in the right direction by changing the temp sensor? Or is there really something wrong with the FI system that I need to check out? I don't have access to iBeats but I will look around for someone who does if that's what needs to be done.
    I'm very new to these bikes so I'm not quite sure the route I should take. Any help would be greatly appreciated! Thanks in advance!
  2. Yossarian Husqvarna
    the 'Ha
    2008 TE610
    Multistrada 1200 Enduro; Tiger 800XC
    Was it three flashes of the N light?
    That usually signals a temperature sensor failure. Replacing the sensor cured it, in my case.
  3. MrBob Husqvarna
    2008 TE610
    DRZ400S
    Yes, 3 blinks then solid for 1 second.
    Another question for everyone...I ordered p/n 8000H3649 because I read Husky superceeded the OEM p/n. Did I order the correct one?
  4. MrBob Husqvarna
    2008 TE610
    DRZ400S
    Figured out what it was....this may come in handy for anyone who has the same trouble.
    So I replaced the temp sensor and the bike still ran the same. Blinking neutral light, it was popping/backfiring, and stalling out. So I figured it had to be something loose or broken. Turns out the 2.2k resistor had a broken lead and was no longer making contact. If I moved it around, it would intermittently make a connection. As soon as I fixed it, the bike ran perfect!
    Just a heads up.
