Help Bike Wont Start...
Discussion in 'TR650' started by Sirjeffery, Sep 26, 2020.
  1. Sirjeffery Husqvarna
    650 Strada
    Husaberg 501 Cbr1000rr repsol cb500x
    2013 Stada was running fine Then died on me the freeway dash dead no power. The main 30 amp fuse blew changed it started and Ran fine. Next day same thing one more time this time on my way somewhere changed fuse no problems after that on that day. Next Day all it dose is blow main fuse when trying to start bike. After blew second time put a voltage meter on it while running seemed normal 13.5-14 volts (don't remember exactly). Anyone else have this problem what was the fix Thanks
  2. mysery1 Husqvarna
    Southeastern NC
    tr650 strada
    I had a loose connection at the positive battery terminal, thanks to my dealer at the time, cause the main fuse to blow. If you installed any accessory lighting or such you might try disconnecting them.
