FE/FC Help change from kph to mph on 2014 te310r?
Discussion in '4st' started by JEBUS151, Mar 11, 2014.
  1. JEBUS151 Husqvarna
    2014 TE310r
    so the other day I just got myself a new husky a 2014, it's the 310 and the units on my tachometer are still in kph. the manual says bring it into any Husqvarna dealer but I know that there are sometimes ways around having to do this so if there's any way I can have these changed by just going into my garage and fiddling with it let me know!
  2. MZee Husqvarna
    East Oregon, USA
    2014 TE310R
    1998 XR 200
    You need 3 hands to do it: Engine off. Press & hold speedo scroll button. Pull clutch & push start button. Keep holding the scroll button untill the km/h or mph symbol is displayed. Release button . Kmh and mph will alternately flash. Push button to select units. It took me numerous tries, I think because I didnt hold the button long enuff to make the units flash after bike started.
  3. huskypiney Husqvarna
    South Jersey
    2013 TE310R
    Do you know if this same process works on the 2013 TE310R?
  4. huskypiney Husqvarna
    South Jersey
    2013 TE310R
    It does work. Based on additional research, I would add that you need to start the bike first and set the display to ODOMETER mode. Then turn off and follow procedure above. 3rd hand a definite must.
  5. MZee Husqvarna
    East Oregon, USA
    2014 TE310R
    1998 XR 200
    When my o' meter was on Km's, the hour meter worked. When I switched to miles the hour meter went dead & stuck on 0. Is there a way to fix this?
  6. BILLF CH Sponsor
    BMP Husqvarna, Salem, OR USA
    92WXC350 /Lamson CR250/701 Vitpilen/
    Triumph900 Scrambler 1200 HD Nightst
    I dont think the hour meter function works on any of them as it used to be the tach.
  7. robertaccio Husqvarna
    San Diego, Ca
    2021 Husqvarna TE300i
    italian red husky question.
