Help cleaning Ti header pipe, baked on dirt
Discussion in 'General (Main)' started by robertaccio, Oct 3, 2010.
  1. robertaccio Husqvarna
    San Diego, Ca
    2021 Husqvarna TE300i
    Help needed from last winters wet SoCal riding I have baked on "clay" type stuff on my headers. I have soaked them in dish detergent, put them through the dish washer scrubbed them and have used scotch brite on them but they still have that reddish/tan earth on them. Any magic bullets you guys know. I have used some of those moto specific dirt removers in the past but its been a while. Muck-off perhaps??? I was thinking to just "bead: blast them, but dont want the rough surface that comes from the media blast. They look like Crap!!! Help
  2. Xcuvator Husqvarna
    Scholls Oregon
    yes
    I have had good luck using increasingly finer steel wool with chrome or stainless polish on it. If really bad start with scotch brite w/polish.
  3. HuskyDude Moderator
    BC, Canada
    13/TR650
    10/EC300, 76/TY175
    Hey Rob,
    I have had great results with Autosol for anything metal.
    Have you tried it?:cheers:
  4. Reddog Husqvarna
    Michigan
    Oven cleaner would be my next step.
    But I have only used it on Aluminum and Stainless Steel.
  5. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    I admit that I just use a wire brush or a wire brush wheel on my TE headers.:excuseme:
  6. HuskyDude Moderator
    BC, Canada
    13/TR650
    10/EC300, 76/TY175
    Ya I forgot that one first...:doh: The Autosol is just to make it shine.:cool:
  7. robertaccio Husqvarna
    San Diego, Ca
    Thanks all, less elbow grease and more food for thought, all the ideas are filed in my head now.
    I completely forgot I had a spray container of S100 moto cleaner, this with a combo of plastic scrub brush and a scotch brite scour pad, did a reasonable clean up. I guess after all the beating it will never have that cool blue shiney patina that the Ti gets when in mint condition. But they look alot better, I just needed to spend more time cleaning and scrubbing and less time thinking and asking, thanks all!
  8. hammer Husqvarna
    Mr. Clean Magic Eraser
  9. pvduke Husqvarna
    ... on the gas...
    tripple-hondo hoosk...
    after you get the solids off and the pipe is smooth, clean etc.
    try blue-away to get the stains off. then polish the header smooth, clean with super mild soapy water, then alcohol, dry and follow up with simichrome.
    bling blang! :busted:
    clean again with super mild soapy water (soapy water carries grit off, WD/petrol based stuff just moves it around), alcohol and no touchy the pipes till you fire it up!
    on ti only use SS wire or plastic brushes.
  10. surfer1100 Husqvarna
    Ottawa, CAN
    09 WR250, Memories of past tiddlers.
    TM-01 EN 125, 03 125 MX, 09 EN 155
    Lagostina Cleaner
    I got it at a Canadian Tire really good stuff.
