Help: Found Bits of plastic in the bag filter
Discussion in '610/630' started by ChrisP, Feb 19, 2012.
  1. ChrisP Husqvarna
    Swedesboro NJ / Deland FL
    2006 SM610 , 2014 TE310R
    Concours 14, GSXR750,
    2006 SM 610, 4000 miles
    Changing the oil today and found bits of flat plastic in the bag filter on the left (shifter) side. The transmsision and right side bag filter are clean. Any ideas ?
  2. ChrisP Husqvarna
  3. organ donor Husqvarna
    Berlin
    How big are the pieces? Pics???
  4. gabik Husqvarna
    sm610s
    guzzi nevada
    they are flaking pieces of excess glue keeping magnets to flywheel. i did not see mine popping off but all glue flaked away now. not bothered - cleaned oil filters and using bike as normal..
  5. gabik Husqvarna
    sm610s
    guzzi nevada
    excess glue keeping magnets on flywheel. nothing bad. clean it all and inspect flywheel of magnets keeping in places
  6. ChrisP Husqvarna
    Stand by, Trying to upload pics
  7. ChrisP Husqvarna
    Lets see if this works
  8. ChrisP Husqvarna
    Here's a pic. They are flat brittle and color is orange / yellow
  9. organ donor Husqvarna
    Berlin
    Looks like Gabik´s right! I´d keep my eye on it and do the filter again soon.
  10. ChrisP Husqvarna
    Thanks guys, Strange but it makes sense. Based on the oil flow scematic, and where it was located in the filter, the stuff came from ignition side of the engine. I was thinking plastic from a chain cam tensioner but since I've never had it apart I didn't know if there were plastic components in there. Closer inpection reveals that it's too brittle to be a plastic component. So glue makes sense
    Thanks again !
  11. Mastroser Husqvarna
    Trieste, Italy
    I had the same problem. I cleaned the filter and had any problem after...
  12. gabik Husqvarna
    sm610s
    guzzi nevada
    they are orange n most cases, mine popped out and magnets still on place but i have heard about loose magnets.. worth to inspect when oil is out...
    as you can see on picture on lhs there is bit left...
  13. Coffee CH Owner
    OK... I finally realized why I was confused, there were 2 virtually identical threads started by the same person at about the same time - there was probably a technical issue with the site.
    I merged the 2 threads to avoid more confusion. Hope that is ok.
  14. ChrisP Husqvarna
    Yes, that was me. The first time I posted I got an error message that said failure due to data base conflict. I backed up and re-entered and then their were 2 identical posts. Sorry for the confusion
