HELP- Husky swing-arm bolt!
Discussion in 'Vintage/Left Kickers' started by frog, Sep 21, 2009.
  1. frog Husqvarna
    MN
    I'm putting together a 1983 Husky 250 and the swing-arm bolt doesn't seen long enough? On one end the nut is flush with the threads and the other end hardly has enough to start the threads? This bike was a project someone else started,so I didn't take it apart. Will it pull together when tightened?:banghead:
  2. Leftcoast leftkicker Husqvarna
    encinitas ca
    Sounds like you have the wrong one,, it should slide all the way thru w/about half the threads extending so that when you tighten it up there'll be about an 1/8" +/_ left on each side.
  3. Motosportz CH Sponsor
    Maybe try getting both sides a good half a nut thread and working them on from each side. There might be enough slack in a new assembly / paint to take up some space that will come back some when you tighten the nuts. :excuseme:
    BTW the resto looks great. :thumbsup:
  4. pcnsd Husqvarna
    San Marcos, CA
    Some thoughts to share, maybe applicable, maybe not.
    With the motor installed and the swingarm in position, is there gap(s) between the assemblies that would explain the apparent short bolt? There should be no real visible gaps, if so the frame is likely sprung/tweaked from a hard landing or crash. You will need to clamp it together enough to start the bolt and then pull it together per Motosportz.
    If there is no gap between the assemblies, then Leftcoast leftkicker's "Wrong one" advice would seem sound. Source the correct bolt from a vintage Husqvarna supply guy.
    Nice looking ride!
    Regards,
    PC
  5. schimmelaw Husqvarna
    Rowlett, Texas
    Frog,
    Some measurements that might help. Bolt size is 12mm. 1.0 thread pitch. 9 11/16" length.
    Bike looks good.
    Rick
