help Identify fork part
Discussion in 'Older Single cams' started by tahoesteve2659, Apr 2, 2015.
  1. tahoesteve2659 Husqvarna
    1994 610 TE
    I have a 94 610te with Showa usd 45mm front forks.
    I had to replace the pumping mechanism which came from France.
    After put everything back together...one of my clickers still wasn't functioning correctly so I took it back apart to compare the two. after i drained all the oil i noticed this tiny little piece in my oil pan.
    I do not have two of these....not sure where it goes exactly....not sure how to get another one.
    Should this piece have come with the pump i ordered? If not...anyone know the part # for this piece?
    The manual for my bike does not show this piece.
    The manual for these forks says nothing about this piece nor show it.
    I took the piece to ktm.....they don't have one.
    I think it may go to my bike forks but unsure why i can't find pictures, diagrams, or a part #
    Thanks for the help.
    0401151359.jpg 0401151405.jpg .
  2. Sund Husqvarna
    Denmark
    TC610 1990 frame. Approx 1997 engine
    BMW R60/6 1976, Sold. YZF 250 Sold.
    Do you have the parts manual, with the exploded-view pictures?
  3. Up-tite Husqvarna
    That's how it goes.
    Later George
    oldbikedude likes this.
  4. tahoesteve2659 Husqvarna
    1994 610 TE
    This is the parts fiche that i found for this bike. it does not show this piece nor give a part #.
    Thanks for your help
  5. tahoesteve2659 Husqvarna
    1994 610 TE
    George...do you mean that i have the parts in the correct order? if so do you know the part #? Is this part supposed to come with a new pump?
    Or do you mean "that is how it goes" when working on Husky's? I have gotten the latter response from many. Lol
    Thanks
    justintendo likes this.
  6. rancher1 Husqvarna
    WA
    That is how it goes in this case means it is correct.
  7. Up-tite Husqvarna
    Rancher 1 reply is what I mean.
    Also with Husky sometimes the parts fiches have been a year behind. By this I mean the the part would not be on say a 1994 fiches but would be on the 1995 if the same part was used.
    Later George
  8. tahoesteve2659 Husqvarna
    1994 610 TE
    You are correct. I have the parts manual for a 1995. Seems they changed the suspension from 1994 to 1995. I have a Showa front and rear apparently on my 1994. I can find even less info online about these.
    Now I am unsure which Showa's I have exactly: doesn't say in the parts fiche (nor show my missing part). There is no manual I can find online for a 1993 or 1994 husqvarna. Tried buying one online that stated it was a "1994". They sent me the 1995 mostly in German (which is available free online). This manual is also useless for my forks (different forks).
    Inverted? USD? Any Idea on which models came on these 93-94 bikes? How many mm am I looken at: 43, 44, 45mm etc?
    Thanks
  9. rancher1 Husqvarna
    WA
    93-94 are 45mm usd showas, 95 are 43mm usd showas.
  10. tahoesteve2659 Husqvarna
    1994 610 TE
    Anyone know where to get a detailed diagram of this showa usd fork? The parts fiche has a diagram but doesn't show the inner parts of the plumbing mechanism nor show this mystery piece.
    Which Showa usd fork model is on a 1994?
    What other bikes (Honda, Kawasaki, KTM, etc.) where fitted with these exact forks? Perhaps they have a more detailed diagram and available part#.
    The 1995 Husky model has a different part # for the pumping device then the 1994 Husky. Does this mean (as i think it may) that these parts are not interchangeable? If so...the only parts i can order for forks (and diagrams I can use) are from a 1993-1994. Please correct me if i am wrong because this will definitely open doors for parts and diagrams (i hope / probably not).
    If I have to get new forks entirely...What years of Husky (or non-Husky) will fit on this bike? Does how the front brake connect to the fork vary with the model, year, etc of the fork (or bike)?
    This tiny little piece is preventing me from riding.
    Grrrrrrrrr
  11. rancher1 Husqvarna
    WA
    The 93-94 models used the 45mm usd showas. George told you earlier that you have the correct idea of where it goes in your picture. George was a husky dealer forever and a known guru for the brand. You should assemble it and go riding. I did the reseach for you try this link for a 1993 suzuki rmx 250 https://www.rockymountainatvmc.com/oem-schematic/2 you want to look at the front damper (model N) parts #11, 12, 13. The internal specs are made to manufacturer specifications so I would not bet on every part fitting both forks but it is the same model. I hope this is enough information for you to assemble it now.
  12. tahoesteve2659 Husqvarna
    1994 610 TE
    Thank you both for all you help. I would not have been able to figure this out without you two. Been doing research for weeks with no luck.
    Rancher1 that is the first diagram that I have been able to see this missing piece! stoked.
    I ordered the Suzuki part that is missing from my forks (Needle). I know it is a gamble on if it will fit (as you stated)....but $20 is a good gamble vs. entire new forks.
    I will update this post on the outcome of these possible compatible parts.
    Thank you again
