125-200cc Help! Inner clutch cover damaged.
Discussion in '2 Stroke' started by Morgan, Aug 22, 2012.
  1. Morgan Husqvarna
    WR 125 2011
    Aprilia Pegaso IE 650
    Hi there. Great forum!
    I´m from Denmark and been lurking here for a while before i finally pulled the trigger on a low hour WR 125 ´11. I absolutely love it:)
    But yesterday the fun stopped when a big stone hit the underside of the inner clutchcover (crankcasecover) and bended it so the clutch actually rubs against it inside and oil is pouring out between the inner clutch cover and outer clutchcover (the one with the sight glas)...
    So now i need to replace the two covers. Buhuu!
    My question is: will the inner clutch cover from an ´07 fit on my ´11?
    I found a cheap new one on ebay from an ´07 and it looks the same but the partnumber is different from an ´11. The outer cluch cover is same partnumber on ´07 and`´11.
    BTW, my bike has the orignal skidplate.
    Regards, Morgan.
  2. R_Little Husqvarna
    NJ
    They are the same on the 125 back to 2000 at least and maybe 1998.
    The SMR they sell in Europe might be different though.
  3. Morgan Husqvarna
    WR 125 2011
    Thanks for the reply:-)
    I´ll order it straight away, so i can get back on my baby;)
  4. Morgan Husqvarna
    WR 125 2011
    Do I need to dismantle the adjustable powervalve arm and the parts going in to the guvorner in the inner clutchcover to remove the cover? Hope you understand what I mean... Any tips on this little job will be appreciated very much:-)
