HELP. Need RH Upper Engine Mounting Hardware
Discussion in 'TR650' started by TE250Guy, Apr 5, 2017.
  1. TE250Guy Husqvarna
    Washington
    2008 TE250, 2013 TR650 Terra
    2009 KLR 650, Yamaha XT 225
    On a recent adventure ride, the engine mounting and related hardware departed. I should have used loctite blue when I installed the AltRider crash bars. My Bad. I have checked the usual places and they all say unavailable with an uncertain availability date. Here are the items in question:
    Bike: 2013 Husqvarna TR 650 Terra
    Code: 9903801
    Name: INT/TORX SCREW M10X40-8.8-ZNS3
    Quantity: 1
    Code:
    8A00H7716
    Quantity: 1
    Code:
    8000H7716
    Quantity: 1
    There were two spacers listed and I am unsure which applies so I ordered both. There is a washer as well that was not backordered.
    I checked with several Husky dealers with no joy. I also checked with BMW in the off chance the same parts are used on their 650 model, but abandoned the search after taking up too much time of the service guy.
    Any secret places that I can find these parts?
  2. CarstenB Husqvarna
    NL
    F650GS Dakar
    TE250Guy likes this.
  3. TE250Guy Husqvarna
    Washington
    Thanks for the prompt and helpful reply. Tacoma Screw, local to me, has a socket head cap screw in that size for cheap! It is in shear so should be OK. Can buy just one for less than $1. http://www.tacomascrew.com/s.nl/it.A/id.7685/.f For the spacer I can either make one or go the ghetto route and stack washers. Maybe use these or Stainless washers. http://www.tacomascrew.com/s.nl/it.A/id.69944/.f
  4. TE250Guy Husqvarna
    Washington
    Can anyone with a tr650 Terra check their RH upper engine mount spacer and see if it is white or black?
  5. PaulC F class
    Bayside Brisbane, Australia
    TR Terra
    Black
  6. CarstenB Husqvarna
    NL
    F650GS Dakar
    silver/white
    i guess either the 10mm or 11mm spacer was used to account for tolerances in the fit.
    PaulC and TE250Guy like this.
  7. TE250Guy Husqvarna
    Washington
    Looks that way. Guess I can measure.
    BTW, found what looks to be a BMW equivalent except it is a socket head and not a torx.
  8. PaulC F class
    TR Terra
    11 mm,
  9. PaulC F class
    TR Terra
    got any photos you can look back on?
    Thats extortion :eek: for us aussies
    Anyway, these an saying in Italian
    Abbastanza vicino e abbastanza buono
  10. TE250Guy Husqvarna
    Washington
    [quote="PaulC, post: 614070, member: 14927"
    Abbastanza vicino e abbastanza buono[/quote]
    Good idea. The spacer is pretty well hidden by the frame and crash bar but maybe I can find a photo and see just enough to get the color. Another option is to get the thicker one and grind it down if it doesn't fit.
    PaulC likes this.
