Help needed with a 1981 420 AXC.
Discussion in 'Vintage/Left Kickers' started by DG29, Nov 12, 2015.
  1. DG29 Husqvarna
    198 420 AXC
    71 Hodaka Super Rat, Suzuki Tm
    Hi, new member here. I have recently acquired a 1981 (or 82 ) 420 AXC 4-speed.
    After purchasing the bike I needed to get a new gas tank for it and clean the carb since it was stored away in a desert airport hanger since 1990. Anyway, I've taken the bike to George down in Santa Ana Ca. to clean the kick starting one-way bearing since it was not engaging every time. He had told the everything looked good but that this bike has had some mods done to it. The swing arm is slightly longer, the front had been slightly raked, and that the exhaust pipe was not original Husky. We test rode it and the bike, engine and transmission work perfectly and the bike is a flat out rocket. In fact, he had told me that I needed to ride it harder on the throttle and I'm getting a bit too old to ride like that. In the little research that I've done I've noticed that the 81-82 420's did not come with these factory shocks. Anyway, I will have a new title for the bike and I think that I will just sell it because if something breaks on it I will not be able to afford to repair it.
    So my question is doe anyone on this forum know what the value of a 81 420 AXC would be in this condition?
    Thanks in advance,
  2. Michel Dufayard Husqvarna
    France
    The frame is 83. So the shocks are ohlins ITC 83-84 which are on 83-84 frame. The fork is 35 mm.
    The pipe is husky but not the AXC surely a cr/wr/xc 81-82-83 (430 ?).
    The silencer is an aftermarket.
    Not sure
    For the value put an add and see !
    Can you put some close-up pics of swing arm and of the other side ?
  3. everfree Husqvarna
    Bend, Oregon
    86 430AE (2), 88 430AE, 87 430WR (2)
    87 250 XC, 87 430 CR, '17 GG 300
    Interesting.
    Sounds like someone built a bike around a good 420 engine.
    The engine looks to be an 82 by the silver, not black, cylinder.
    IMHO, since it's not all original, the real value is in the Auto engine. Auto engine parts are hard to come by.
  4. DG29 Husqvarna
    198 420 AXC
    The Frame is a 81-82, (CN01191) George looked it up. I have titled the bike as a 81 (as he had advised me to) and the pink slip showed up today. The engine plate shows it as 2085 0199 . Its a 4 speed and moves through all of the gears, George took it up to about 85 mph. I'll put up a couple more photos when I get a chance later today.
  5. DG29 Husqvarna
    198 420 AXC
  6. stormer254 Husqvarna
    England
    More than I dare let her know
    Yes!
    A frame number would help identify it.
  7. visiteur1948 Husqvarna
    france Europe
    husqvarna only
    original husqvarna
    420 AE 1981
    you have a frame
    CR 1983 /84 !
    pipe 83/84
    is a bitza !
  8. DG29 Husqvarna
    198 420 AXC
    The Frame number is (CN01191). The tank, seat and side plates are more like a 84 500 AE. The bike was sold to me as a 84 500 AE Hi-Flite by the original owners widow. It also has a large aluminum non- Husky air box. I actually like the look ( and probably function ) of what someone has done with this 420 but it is not as the factory had originally outfitted the frame....I think. Included in the sale was two bottles of the original Husqvarna Automatic transmission fluid with one being full and the other empty. I goes out today on a ride to warm it up and flush the transmission fluid as George had suggested I do. Golden Spectro two stroke exhaust smoke will be in the air! :)
  9. DG29 Husqvarna
    198 420 AXC
    In regards to the silencer on the pipe, I placed that sticker on it and have no idea what manufacturer made it. As to the frame, George looked it up and I've looked it up and it is a 81 to 82 AXC. Someone may have put another year swing arm on it, as George had mentioned that it was longer. Taking all of this into consideration, does anyone have a guesstimate as to the value of this 420 AXC ?
  10. Kartwheel68 Husqvarna
    Newnan, Georgia
    Definitely an 83-84 frame.
  11. PEZBerq Husqvarna
    Brisbane, Australia
    390AMX, 430XC, 240WR, 2x510TE, FE501
    It has an 84 air cooled model tank - looks like it's been painted so expect it to peel off. Frame is 83/84/85 and not 81/82. Alloy air box means it definitely was a project bike for someone - impressive going to that effort. Lengthened swing arm probably means it was a WR/AE swing arm converted to longer CR/XC spec for desert racing maybe? Skinny 35mm forks are possibly off the 81WR or earlier bike that was the source of the motor. HyFlite is just the seat cover manufacturer - nothing to do with the bike modifications as far as I know. Very interesting mix of parts and other than the skinny forks is probably quite a nice machine. Value is in the eye of the beholder here as it is a hybrid. Expect it to be worth less than an original model. Good luck with this bike!
  12. Kartwheel68 Husqvarna
    Newnan, Georgia
    Its not an AE/WR its a CR chassis, no rear frame loop and the rear brake pedal is the CR style. The CN frame number indicates an '81 CR, I think what you have there is an '81 CR chassis with '83-'84 ITC shocks, '83-'84 Clarke aftermarket tank and a 420 auto engine.
  13. Kartwheel68 Husqvarna
    Newnan, Georgia
    Nevermind, on looking at it closer, its obviously an '83-'84-'85 twin shock frame.
  14. jo360 Husqvarna
    perth australia
    1983 exc framed wr430 engine
    ktm 520exc
    1981 with modified frame and modified swingarm, anybody who can make the airbox out of aluminium woudl be able to mod the frame.the triangular section under the seat looks too vertical for an 83 and the swingarm has two sets of holes, but maybe its an auto thing.
  15. SteveJ Husqvarna
    New Mexico
    1970 400 Cross, 1983 500 CR
    84 Honda CR500R, 81 Honda CBX,
    Agree with jo360, the frame section below the seat is too vertical for an 83, 84 frame. Here's a picture of my 83 for reference, the upright member that the shocks attach to leans forward on 83, 84. Must be a modified '81 frame with ITC's. Just my humble opinion. Interesting bike.
  16. troy deck Husqvarna
    Republic MO
    87 250wr 12 cr125
    kx65 ty80 rm80 kdx250
    YEP A PROJECT BIKE FOR SURE ALL 80 TO 84 PARTS IF IT HAD AN 87-88 FRONT END ON IT I'D RIDE IT
  17. SteveJ Husqvarna
    New Mexico
    Heck, I've always wanted to try an Auto
  18. PEZBerq Husqvarna
    Brisbane, Australia
    Good spotting on the CR brake and unusual frame mod. It does seem to be an earlier frame modified to take the ITC shocks like an 83/4. Very interesting......
  19. SteveJ Husqvarna
    New Mexico
    It is interesting to see how many details the Husky riders on here pick up from photos of a bike.
    I suspect that the swing arm had to have another hole placed farther back as the ITC shocks would likely have been too long when mounted to the forward hole.
    That Hi Flite seat going that far up the tank seems like a good idea.
  20. troy deck Husqvarna
    Republic MO
    87 250wr 12 cr125
    I HAD A SEAT LIKE THAT IN WHITE ON MY 81 430XC
